Topic: EAC cfg profiles - invisible? (Read 6510 times) previous topic - next topic
  • bluto
I've been using EAC for a month or two now - superb software.
One thing is baffling me, though - the cfg profiles. On my old computer (Windows XP), I could see them in Windows. On my new computer (Windows 7), which is now running the latest version of EAC, I can't see the cfg profiles at all in Windows, although they are accessible from within EAC.
Even with "show hidden files" and "view protected files" checked in Windows folder properties, I still can't see the EAC cfg files in Windows. Using a "dir" command in a DOS window doesn't help either. Anyone know what is going on here? Not a major issue I know - I'm just curious!
Thanks,
Bluto
  • greynol
  • Global Moderator
Where are you looking for these profiles?  Did you look in the directory for your user account?
  • bluto
Thanks for replying.
I saved the EAC profiles in this directory:  C:\Program Files (x86)\Exact Audio Copy
When I go to load a profile from within EAC, they show up in the window alongside the subdirectories I would expect to see (CDRDA0, Documentation etc). If I look in here using Windows, I see all the EAC subdirectories and files except for the cfg files.
I've just tried saving a profile to
(1) C:\Program Files (x86)the desktop.
(2) C:\
(3) Desktop (i.e. C:\Users\bluto\Desktop)
All are accessible from within EAC, but only (3) is visible in Windows...
In case it's relevant my account in Windows is an admin account.
Bluto
  • lvqcl
  • Developer
Maybe they are in "C:\ProgramData\Exact Audio Copy" folder.
  • bluto
No - just checked. Think it's a bug in either EAC or Windows 7.
Bluto
  • Apesbrain
The default location for these files is:
C:\Users\<user>\AppData\Roaming\EAC\Profiles
AppData is a hidden folder.
  • Last Edit: 22 March, 2011, 07:44:52 PM by Apesbrain
  • bluto
Nothing in that location for me.
If saving to a location where it becomes invisible in Windows (such as in C:\, or C:\Program Files (x86)\Exact Audio Copy), then the icon that shows when trying to load from within EAC has a little padlock on it. If I save to the Desktop, or in My Documents, then the icon is visible in Windows, and this icon has no padlock whether viewed in Windows or from within EAC.
I think it's a Windows 7 issue.
Bluto
  • Fandango
EAC is a program that was designed with the user having adminstrative rights on the system in mind.
The profiles are stored in Virtual Store:
"C:\Users\<username>\AppData\Local\VirtualStore\Program Files (x86)\Exact Audio Copy\"
  • bluto
Thank you - I've found them!!
Bluto
