Topic: An APE file that won't decode (Read 1788 times) previous topic - next topic
This is not a biggie for me, but I have stumbled on a Monkey's Audio file that won't decode. The file decodes fine with other tools like dBpoweramp (codec R10), CUETools, Monkey's Audio GUI v.4.06 and MAC.exe v.4.06. The file's PCM content is fine. I can convert it to FLAC or Wave with other tools and the converted files work normally in fb2k.
It is a test file for checking cue converters' and players' timing accuracy. It contains only a few "ticks" that mark the track boundaries, otherwise it is silent.
Item: "F:\Test\ape problem\cue_accuracy_test.ape"
Error: Unsupported format or corrupted file
1 item could not be correctly decoded.
List of undecodable items:
1 out of 1 tracks converted with major problems.
Source: "F:\Test\ape problem\cue_accuracy_test.ape"
  Error decoding source file at 34:29.920 : Unsupported format or corrupted file
MAC.exe v.4.06 verifies it OK, but interestingly the old MAC v.3.99 has the same problem as foobar2000:
F:\Test\ape problem>mac cue_accuracy_test.ape -v
--- Monkey's Audio Console Front End (v 4.06) (c) Matthew T. Ashland ---
Verifying...
Progress: 100.0% (0.0 seconds remaining, 4.1 seconds total)
Success...
--- Monkey's Audio Console Front End (v 3.99) (c) Matthew T. Ashland ---
Verifying...
Progress: 90.1% (0.9 seconds remaining, 8.4 seconds total)
Error: -1
foobar2000 v1.1.5 & Monkey's Audio Decoder v. 2.1.5
The file is available here: http://www.hydrogenaudio.org/forums/index....showtopic=87527
