Topic: Foobar & cue tracklists (Read 3431 times) previous topic - next topic
  • bakis
Hi there.
Decided to try Foobar and so far I'm impressed. Wondering something tho, with winamp I used an addon called Mp3cue.
In mp3mixes that had the info embedded  in the cue I were able to see where a specific track started within that mix as well as the usual artist, songname etc.
My question is, is this possible with Foobar? I am lisstening alot to trance and mixes are a big part of the genre and I really miss pinpointing when for example track 5 starts within that 120min mp3
Cheers
  • marc2003
AFAIK, mp3 doesn't support embedded cue sheets so i'm assuming there is some custom trickery/hacking going on with that winamp plugin. it would work fine in foobar if it was an external cue sheet.
  • bakis
Think they are, but I dont see any UI element that are meant to display it.
PERFORMER "VA"
TITLE "Sensation White 2007"
FILE "101-va_-_sensation_white_2007_cd1.mp3" MP3
  TRACK 01 AUDIO
    TITLE "I Found U"
    PERFORMER "Axwell"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Counting Down The Days (Axwell Remix)"
    PERFORMER "Sunfreakz & Andrea Britton"
    INDEX 01 03:42:00
  TRACK 03 AUDIO
Thats from the cue, so what element is supposed to display it in Foobar?
  • Last Edit: 06 March, 2011, 08:51:57 PM by bakis
  • lvqcl
Playlist. Just load .CUE file in foobar2000.
  • db1989
  • Global Moderator
You’d be amazed at what might happen if you just load the cue sheet into foobar2000 (via File, or right-clicking, or however you prefer).
Edit: I’m too slow!
  • Last Edit: 07 March, 2011, 03:41:42 AM by dv1989
  • bakis
Not what I was after tho. Want to keep the playlist intact, based on actual mp3 files in it and just a separate UI element displaying the mixmp3 cue when it encounter a mp3 and sense there is a cue file in the same dir corresponding to it.
  • shakey_snake
  • Moderator
Well, fb2k isn't other players. It handles cuesheets natively, in a transparent manner. You can always create and maybe then delete a new playlist to inspect the cuesheet, though.
  • Last Edit: 07 March, 2011, 03:57:41 AM by shakey_snake
elevatorladylevitateme
