Topic: foo_flv (Read 41611 times) previous topic - next topic
  • fismineur
foo_flv
Allows you to play Flash Video (.FLV) files on foobar2000.
This currently supports PCM, MP3, and AAC audio codecs.
Download Flash Video Decoder 0.9.0: [ Attachment Invalid Or Does Not Exist ]
  • Last Edit: 21 February, 2011, 08:40:35 PM by fismineur
  • fismineur
foo_flv
Flash Video Decoder 0.9.1: [ Attachment Invalid Or Does Not Exist ]
  • Improved detection of AAC profiles.
  • Fixed incorrect handling of MP3 frames.
  • fismineur
foo_flv
Flash Video Decoder 0.9.2: [ Attachment Invalid Or Does Not Exist ]
  • Improved streaming support. Some streaming files still don’t work.
  • fismineur
foo_flv
Flash Video Decoder 0.9.3: [ Attachment Invalid Or Does Not Exist ]
  • Added tag writing and ReplayGain support.
    All of the Tag Writer Validator tests passed, but please use at your own risk.
  • fismineur
foo_flv
Flash Video Decoder 0.9.4: [ Attachment Invalid Or Does Not Exist ]
  • Tag editing improvements and speed optimizations.
  • fismineur
foo_flv
Flash Video Decoder 0.9.5: [ Specified attachment is not available ]
  • Minor performance improvements.
  • doublehd
foo_flv
thank you so much for the plugin,it works on my V1.1.8
foo_flv
Thank you very much
This component work in fb 1.1.10
  • a2621379
foo_flv
Download Flash Video Decoder 0.9.0: (Attachment Link)
Thank you
  • devcon
foo_flv
Flash Video Decoder 0.9.5: (Attachment Link)
thank you so much
  • Porcus
foo_flv
Dang. Didn't know this existed. Well since I have learned to reencapsulate into mp4, I will go on doing that ...
  • hgx
foo_flv
Thank you.
This plugin is very userfull.
but it not work with ".f4v" Extension file.
i wish you can fix it at next update.
  • 80T
foo_flv
I've been looking for this for a long time. Big THX fismineur
I was losing faith that such plugin will be ever made for foobar2k...
Now I can listen all my music in foobar Woot!
  • Last Edit: 21 December, 2012, 06:53:24 AM by 80T
foo_flv
not work on foobar2000 v1.2 beta 2
  • lvqcl
  • Developer
foo_flv
And it seems that it doesn't work correctly with HE-AAC encoded audio tracks.
  • Porcus
foo_flv
Another two reasons to extract the streams and reencapsulate them in .mp4 or .m4a.
(Is there any downside to this unless you depend on having the precise original file? Assuming that the streams fit the MP4 container, that is? (Could foo_flv play those which cannot?))
  • fismineur
foo_flv
  • fismineur
foo_flv
Flash Video Decoder 0.9.6: [ Specified attachment is not available ]
  • Added support for foobar2000 v1.2.
    The previous versions of foo_flv can not decode AAC audio with foobar2000 v1.2.
foo_flv
Thanks for update
  • antonyb
foo_flv
I downloaded the file, it tells me that it is damaged, why?
  • EpicForever
foo_flv
Just redownload it. If problem persist use other browser (IE if you are normally using FF or other way round).
BTW:
Thank you fismineur for this component so much. When combined with Converter component it allows to do everything with audio from YT...
  • antonyb
foo_flv
BTW:
Thank you, I already got it.
