Topic: OptimFROG version 4.910b [2011-02-10] (Read 16780 times) previous topic - next topic
RE: Monkey's Audio and its reliability
Reliability? It's up there with FLAC, TAK, WavPack, and definitely is a great alternative to Monkey's Audio if one wanted to switch over to OptimFROG.
I've since found out that Monkey's Audio supposed lack of error robustness just isn't true:
http://www.hydrogenaudio.org/forums/index....st&p=434126
http://www.hydrogenaudio.org/forums/index....st&p=498272
Of course, the ideal setting with that codec is -c3000. Best balance between compression, decompression and playback. The equivalent setting in OptimFROG? The total opposite is the case.
  • Ljubo44
I solved the problem by using the --headersize option to specify that the wave header size should be 44. So my foobar2000 command line ended up looking like this:
--encode --mode high --silent --md5 --incorrectheader --raw --headersize 44 - --output %d
And both the original and duplicate passed the bit comparison test...
But witch command is for 24 bit files and different sample rates. eg 24/96
EDIT: Solved. For 24/96
--encode --mode high --silent --md5 --incorrectheader --raw --headersize 44 --sampletype SINT24 --rate 96000 - --output %d
No differences in decoded data found.
  • Last Edit: 18 October, 2011, 07:23:17 PM by Ljubo44
  • Ljubo44
I have another question. When ofr.exe encode DTS CD wav, playback is noise. Same is in Takc.exe. WavPack and FLAC works with DTS CD.
This is what is changed in WAV header after decode from OFR.
Original DTS CD WAV header
Decoded
so, what will be command line for dts cd wav. OptimFrog is best compressor for strong wide range noise.
  • lvqcl
  • Developer
And what's the length of the original and decoded files?
  • Ljubo44
Same lenght, same number of samples. Bit compare tells: No differences in decoded data found. Only playback is problem. I have dts decoder in foobar. But when playing OFR its strong noise.
  • lvqcl
  • Developer
Reply #30
This is strange, because the only difference between those headers is the size of audio data (i.e. number of samples).
And this is not strange: OFR plugin doesn't support postprocessing that is required by newer DTS decoder plugin. You can use older foo_input_dts ver. 0.2.8.
  • lvqcl
  • Developer
21 Jun 2015
After an exceedingly long apparent pause, the OptimFROG 5.000 stable release is finally ready! It is the result of a large number of internal code updates and improvements, featuring several new supported platfroms, SSE2 enabled builds, a fully new unified license, updated SDK, updated documentation, and updated website content. You can check all the new release packages on the Downloads page and the comprehensive list of changes on the Changes page.
http://www.losslessaudio.org/News.php
  • Last Edit: 11 July, 2015, 07:38:50 AM by lvqcl
http://www.hydrogenaud.io/forums/index.php?showtopic=109553 ?
I wonder why it's stuck in "news submissions"
  • lvqcl
  • Developer
Reply #33
Oops. Somehow I missed it completely. Thanks, ChronoSphere.
