Topic: Still cannot convert files to WMA with Foobar (Read 20697 times) previous topic - next topic
  • superbu
I know numerous people have had this problem -- there are a couple threads dealing with it -- and I've tried everything suggested on this site that has worked for other people.  But no matter what I do, I get an error when converting a file to WMA format in Foobar.  It looks like it's converting the file just fine, but I get an error message at the end saying, "An error occurred while finalizing the encoding process (Object not found)."  However, I can convert files to WMA with dBpoweramp with no problem whatsoever.
I've tried changing the specified encoder to cscript.exe, trying all variations of the command lines suggested.  I've also tried the hot fix for WMA from Microsoft.  Both suggestions were made in this thread and have worked for other people:
http://www.hydrogenaudio.org/forums/index....47759&st=50
I also tried copying the cscript.exe file into the Foobar folder, as someone suggested.  Didn't work.
No matter what happens, I get the error, "An error has occurred while finalizing the encoding process (Object not found)."  And no file is created, though an unnamed folder is created if I have Foobar set to create a folder with the artist name.
I am using the latest version of Foobar 1.1.2 on Windows Vista Home Premium 32-bit, with User Account Control turned off.  My installed components are ABX Comparator, ALAC Decoder, Album List, Audio CD Writer, CD Audio Decoder, Converter, Default User Interface, File Operations, foobar2000 core, freedb Tagger, Masstagger, Monkey's Audio Decoder, ReplayGain Scanner, Standard DSP Array, Standard Input Array, and ZIP/GZIP/RAR Reader.
Anyone have any ideas?
  • kode54
  • Administrator
Try converting to WAV files of various formats and running that tool on them manually. Start with 32-bit, then move down to 24-bit and 16-bit. If it fails on any of them, adjust the maximum bit depth of your converter output format preset accordingly.
  • superbu
I'm not sure I understand what you mean.  Do you mean create different WAV files, ranging from 32 to 16 bit, then try to convert them to WMA?  If so, I just tried that, and it failed on all of them.  I then changed the maximum bit depth of the output to 32, and I still got the "Object not found" message when finalizing.
  • superbu
By the way, if it helps to know this, I also cannot burn a CD with Foobar.  I get the error message, "CD burning initialization failed: Unknown error code (0xC0AA020C)".  They may be unrelated.
  • kode54
  • Administrator
I meant to try feeding the resulting WAV files to the tool directly, from a command prompt, not using foobar2000.
  • tpijag
Feed (0xC0AA020C) to search box. Lots of information.
  • lvqcl
  • Developer
What't your settings, exactly?
  • superbu
They're in the next-to-last paragraph in my first post.  EDIT: Oh, if you mean my WMA settings, I've tried at least three:
Encoder: C:\Program Files\foobar2000\WME9.vbs
Parameters: -silent -a_codec WMA9STD -a_mode 2 -a_setting Q98_44_2 -input %s -output %d
and
Encoder: C:\Windows\System32\cscript.exe
Parameters: "C:\Windows\System32\cscript.exe" //NoLogo -silent -a_codec WMA9LSL -a_mode 2 -a_setting Q100_44_2_32 -input %s -output %d
and
Encoder: C:\Program Files\foobar2000\cscript.exe
Parameters: "C:\Program Files\foobar2000\cscript.exe" //NoLogo -silent -a_codec WMA9LSL -a_mode 2 -a_setting Q100_44_2_32 -input %s -output %d
  • Last Edit: 09 February, 2011, 12:16:05 PM by superbu
  • superbu
I unfortunately don't know how to use the WMA encoder from a command prompt.
  • lvqcl
  • Developer
First, download and install Windows Media Encoder.
Next, use correct settings:
Parameters: "c:\Program Files\Windows Media Components\Encoder\WMCmd.vbs" -silent -a_codec WMA9LSL -a_mode 2 -a_setting Q100_44_2_16 -input %s -output %d
Highest BPS mode supported: 16
These settings are for compression of CD audio (44kHz/stereo/16bit) to WMA lossless.
  • Last Edit: 09 February, 2011, 01:00:57 PM by lvqcl
  • superbu
Followed exactly; even cut and pasted your command line; I still get:
1 out of 1 tracks converted with major problems.
Source: "C:\Users\zipzip\Music\Air Supply\(02) The One That You Love.wav"
  An error occurred while finalizing the encoding process (Object not found) : "C:\Users\zipzip\Music\(02) The One That You Love.wma"
  Conversion failed: Object not found
  • kode54
  • Administrator
Have you tried [a href='index.php?showtopic=85654']this[/a]? (Scan the topic for the latest version, although I think the download link has never changed.)
  • eevan
Maybe the filename can make this kind of error. Try not to use parenthesis.
If age or weaknes doe prohibyte bloudletting you must use boxing
  • superbu
Thanks, I didn't see that one.  I did try it with the new WMAenc download and the recommended command line, and the encoder crashes after conversion, so there's no output file.  A temp wav file is created, but it's deleted when the encoder crashes.
  • Last Edit: 14 February, 2011, 03:07:54 AM by superbu
  • superbu
Thanks, but I already tried deleting the parenthesis, deleting the file number, changing the destination folder, everything.
I guess I give up.  I've literally spent six to eight hours total trying to get Foobar to convert files to WMA, and it simply will not work on my PC.  I have no idea why, but unless someone else has any ideas, I give up.  I'll just have to use dBpoweamp's WMA converter, which works perfectly.  Unfortunately, dBpoweramp doesn't support cue files, so all my albums that I've ripped as FLAC are going to have to be converted to separate files lossless files first, then converted to WMA, but I guess I'll just have to take the extra step.  I don't know what else to do.
  • lvqcl
  • Developer
Open commamnd prompt window (press Start-> Run, then type cmd.exe)
Type the following line:
cscript.exe "c:\Program Files\Windows Media Components\Encoder\WMCmd.vbs"
What's the output?
  • superbu
What's the output?
It says:
Microsoft ® Windows Script Host Version 5.7
Copyright © Microsoft Corporation. All rights reserved.
c:\Program Files\Windows Media Components\Encoder\WMCmd.vbs(375, 1) WScript.CreateObject: Could not locate automation class named "WMEncEng.WMEncoder".
  • Last Edit: 17 February, 2011, 01:52:39 AM by superbu
  • lvqcl
  • Developer
Probably Windows Media Encoder was installed incorrectly. Try to reinstall it.
  • superbu
Just downloaded Windows Media Encoder 9 from Softpedia (it's no longer available from Microsoft).  Uninstalled the old version completely and reinstalled the new one.  Typed the command lines you gave above in the command prompt window, and got the identical message:
And of course it still won't work with Foobar.  I'm at a loss.
Not sure if this may be applicable considering that it's from 2009 but I found this: http://support.microsoft.com/kb/929182
  • superbu
Yeah, I tried that.  That didn't work either.  It converts, but still cannot create the output file.  Thanks, though.
  • Apesbrain
If you are running Win 7 64-bit, did you try this foobar2000 converter setup mentioned in another thread?
Encoder: Custom
Encoder: C:\Windows\sysnative\cscript.exe
Extension: wma
Parameters: "C:\Program Files\Windows Media Components\Encoder\WMCmd.vbs" //NoLogo -silent -input %s -output %d -a_codec WMA9LSL -a_mode 2 -a_setting Q100_44_2_16
Format is: Lossless
Highest BPS: 24
Encoder Name: WMA Lossless
Also, depending on the version of WMCmd.vbs you have, you may need to change "-a_codec WMA9LSL" to "-a_codec WMALSL".
  • Last Edit: 27 February, 2011, 02:49:08 PM by Apesbrain
  • superbu
Encoder: Custom
Extension: wma
Format is: Lossless
Highest BPS: 24
I'm actually running 32-bit Vista.  I don't have a Synastive folder.
I just tried deleting the "9" from the WMALSL, as you suggested, and it comes up with the same error: no output file.
I'm still getting the error message "WScript.CreateObject: Could not locate automation class named "WMEncEng.WMEncoder"" when I try to run it through the command line, which I think indicates what the problem is.  However, I've tried reinstalling WMA9 Encoder two or three times, including as administrator, and it makes no difference.  WHAT is causing it to not locate WMEndEng.WMEncoder is what the real mystery is, I think.
One new twist I will add is that I just downloaded a more current version of WMCmc.vbs (from 2007 vs. the 2002 version I have), and when I try to run that with cscript.exe in the command line, I get this error message: "Cannot initialize Windows Media Encoder object.  Please verify that Windows Media Encoder 9 Series is correctly installed on your system.  If running 64-bit Windows, make sure that the version of cscript.exe used corresponds to the version (x86/x64) of WME9 installed on your system."
I know this thread hasn't been active for a while, but I too am having the "An error occurred while finalizing the encoding process (Object not found)" problem when trying to convert to wma.
I couldn't find a .vbs file after installing MS Expression 4, so went with tryingout out dBPowerAMP command line syntax.
I know that, I need to somehow specify an input and output filename and the encoder parameters that are encoder specific.
I have tried:
-input"%s -output %d -convert_to="windows media audio 9" -codec="windows media audio 9.2" -settings="320, 44 Khz, Stereo CBR"
lossy, 16bit,
dBPowerAMP (if running in a cmd window wants -inputfile"..." and -outputfile"..." specified (obviously), but I'm not sure how to action that with foobar2000.
this didn't work either:
-infile=%s -outfile=%d -convert_to="windows media audio 9" -codec="windows media audio 9.2" -settings="320, 44 Khz, Stereo CBR"
It's funny because the conversion progress takes place, but no file is created.  It's really annoying.
I got WMecoder working with Fb2k!!!
I just searched the web for Windows Media Encoder, downloaded the latest version for Win XP SP3 32bit (b/c that's my OS).
I already had it installed (apparently), but repaired the installation.
Put in these, and yes, got a working file.
So I then tweaked to get the file I wanted:
"C:\Program Files\Windows Media Components\Encoder\WMCmd.vbs" //NoLogo -silent -input %s -output %d -a_codec wma9std -a_setting 320_44_2
320 kbs 44.1 kHz Stereo WMA 9.2 Standard.  Compatible with my CD player, and the highest quality it will except (sadly no lossless  - how dumb).
My problem is that the output from this process is not exactly the same as the one output from dBpowerAmp.  I have got to try and find out what the differences are, but it's not identical, so dBpowerAmp is employing something different in there.
