Topic: Low Bitrate Codec? (Read 2774 times) previous topic - next topic
Low Bitrate Codec?
I need some opinions. I am working on embedding a loop into my webpage, and I have many dialup, or low bandwith viewers in the states and UK. I am very impressed with Gark's ~4kbps ogg files, and I have found JOrbis: http://www.jcraft.com/jorbis/
which plays vorbis files to boot.
I am wondering if there are any good alternatives to ogg for extremely low (4-36kbit/sec) bitrate audio? I know preprocessing is a big part of compressibility, but I'd like to know I was using the best codec possible.
Low Bitrate Codec?
AAC+ will probably sound much better than that, but it's not available yet. Nero Digital is supposed to be released in this quarter which lasts until June...
ZZee ya, Hans-Jürgen
BLUEZZ BASTARDZZ - "That lil' ol' ZZ Top cover band from Hamburg..."
INDIGO ROCKS - "Down home rockin' blues. Tasty as strudel."
Low Bitrate Codec?
If you are embedding voice into your webpage, then you should consider using Speex.
EDIT: (Just so you know)
Speex is an Open Source/Free Software patent-free audio compression format designed for speech.
Speex is [...] designed to compress voice at bitrates ranging from 2 to 44 kbps.
Hard work might not kill you, but why take any chances?
