Topic: R128GAIN: An EBU R128 compliant loudness scanner (Read 251192 times) previous topic - next topic
Reply #450
don't work.
What's the problem and how does it manifest? "Don't work" is a rather vague description
It's simple -- all options cover a single simple feature.  Non of those does what it is supposed to do.
1. Output is not quiet
2. Progress is still showing
3. Permissions are still 600 instead of original 666 after files being written ( umask is 644 btw)
4. Owner gets changed
I'm not running my stuff in a virtual environment btw.
THX
  • pbelkner
Reply #451
don't work.
Could you please let us know, at least, the command line you are using?
Reply #452
I also have a problem getting R128GAIN to work as expected.
Despite having a suspicion the solution is embarrassingly simple I'm forced to admit to being stuck.
Download: http://sourceforge.net/projects/r128gain/files/r128gain/1.0/
    Unpack using 7z: http://www.7-zip.org/
    Double click "r128gain.exe" from the Windows Explorer.
    Hit the "Choose" button and select your WAV/FLAC file.
    Hit the "Ok" button.
When I execute the above by starting the exe file I get the R128GAIN v1.0-alpha-6-3(FFmpeg edition) window displayed
and a command line window opens with 'GigItemurl successfully loaded. _' Appears.
When I enter the target file name into the input window and hit 'ok'
the command line window reports
Sox successfully loaded
FFmpeg sucessfully loaded
Done
Hit enter to continue ..
So I hit enter..... and nothing constructive happens.
All windows close.
What am I doing wrong?
Windows Vista 64 system. All drivers and OS fully up to date. No other known issues. Intel i7-920 ASUS P6T Deluxe V2. No o/c.
  • pbelkner
Reply #453
I'm a bit uncertain what you mean by "enter the target file name ...". At a minimum you have to provide an input. If you are interested just in analyzing the input then that's all what is needed.
Reply #454
When I execute (double click on) R128GAIN.exe it brings up a windows command line box and the standard windows parameter box I've seen from other peoples screen shots.
The first option on the latter is labeled 'input' with a choose option. I figure that's the place you enter a target file to be analysed. Right?
Yes. So why does nothing happen? Where should the analysis appear?
  • pbelkner
Reply #455
What kind of file are you adding to the input?
Reply #456
Here's my commandline (started from a bash script):
r128gain --quiet --progress=off --chmod --chown --sox=/usr/share/r128gain/r128gain-tools --r128-2011 --true-peak --gate=-10 --reference=-27 --in-place --tags=rg --db /tmp
  • pbelkner
Reply #457
You should have "--r128-2011" in front of any other option. This kind of option loads a complete profile including all default settings, i.e. this kind of option effectively overwrites any other setting in front of it.
r128gain --r128-2011 --quiet --progress=off --chmod --chown --sox=/usr/share/r128gain/r128gain-tools --true-peak --gate=-10 --reference=-27 --in-place --tags=rg --db /tmp
  • pbelkner
Reply #458
--quiet
won't seem to work in latest alpha-6-3 cli-64.
Meanwhile I've learned that the current implementation is no guarantied to work (cf. e.g. http://www.linuxmisc.com/9-unix-programmer...32581e41ffc.htm). The next release will fix this. Meanwhile you should avoid "--quiet" and prefer the following instead:
r128gain ... >/dev/null
That's exactly the same what the next version will do in the presence of "--quiet".
Reply #459
.mp3  - More specifically a selection of downloads from Beatport which you asked me to take a look at in another thread.
I've tried it with other file types from various sources of course but the result is always the same.
I'm at a loss where to look for diagnostics. Just seems to disappear without leaving a trace.
  • pbelkner
Reply #460
.mp3
In order to allow "r128gain" recognizing MP3 you have to upgrade the FFmpeg DLLs from the folder "r128gain-tools" with their counter parts from the latest Zeranoe build: http://ffmpeg.zeranoe.com/builds/win32/shared/.
Since the alpha-6-3 release they have bumped FFmpeg's libavuitil to version 52. To make "r128gain" working with the latest FFmpeg build from Zeranoe you have also to upgrade "r128gain" to at least alpha-6-4: http://sourceforge.net/projects/r128gain/files/r128gain/1.0/.
Reply #461
THX. I reckon that's a workaround for now!?!?
That's IMO a very "dangerous" behaviour you're describing. People can have settings overwritten without noticing it. Dependencies of options should be covered by the program.
Even if put into the "help" area, the risk of not getting as result what was intented is pretty high.
THX for letting me know.
Reply #462
--quiet
First of all. Good to see that I was not wrong.
Routing to >/dev/null is of course the easy way. Though I'd say it's better to avoid the printfs .
Scripting issue - once more:
Could it be that my earlier reported script problem is also located in the shell environment area.
I'm running all kind of shell scripts since years and never had a problem with loops. You're also running a recursive loop inside your program.
Maybe those loops interfere somehow. This problem is really bugging me.
Cheers
  • pbelkner
Reply #463
I'm not certain what the intention of your script is. I suspect that you try to descent down a directory tree. "r128gain" is doing exactly that.
  • Last Edit: 30 October, 2012, 10:17:16 AM by pbelkner
Reply #464
1. I'm running quite some other actions on my files.
2. I can move files around, I can change permissions
3. I can run tailor made loops with certain search masks
asf. asf
I used to use metaflac for applying rg-tags btw. That worked without problems by handing over *flac.
In my opinion/experience CLI programs don't need to implement  smart recursive functions or similar. Like sox,flac,ecasound,metafac you name it. You hand over a set of files
an that's it. Much less hazzle for the programer.
Reply #465
One more:
If you go for >/dev/null  solution. Please seperate stdout from stderr, to avoid that everything goes straight to /dev/null
>/dev/null  2>/tmp/error.log
Though I'd rather say. Skip the >/dev/null thing. Take out --quiet if you don't intend to surpress the printfs.
THX
  • Last Edit: 30 October, 2012, 11:05:04 AM by soundchekk
  • pbelkner
Reply #466
That's the same with "r128gain": if you provide a list of FLACs it will process exactly these FLACs. You may use wildcards as well, i.e. "*.flac".
As far as I can see, your script does something else. Try the following:
find /tmp  -iname '*.flac' -printf '%h\n' | sort -u
It gives you a list of directories including all sub-directories. "r128gain" will traverse recursively each directory. Your script will having run "r128gain" multiple times on the same sub-directories potentially colliding with itself.
You simply don't need the loop.
That's your opinion. I prefer to have just a program without the need for writing additional scripts.
EDIT: If you change "$I" to something like "$I/*.flac" it may work, provided the shell expands the wildcard.
  • Last Edit: 30 October, 2012, 11:50:07 AM by pbelkner
Reply #467
You missed " my experience".
Mainly all cli tools are pretty basic, though extremely "flexible".
But. Never mind.
I talked too much anyhow.
THX again for providing your toolbox to the community.
I'm outta here.
  • Last Edit: 30 October, 2012, 11:51:26 AM by soundchekk
  • nfranzke
Reply #468
Hello,
i followed this discussion trying to catch the most important points.
i am not into programming, though - being left with a more or less "basic" question concerning the output of r128gain.exe:
basically, the GUI works quite fine, giving me results after having specified input file.(my OS = Win7 64)
But:
1.the resulting analysis (in my case: -25.3 LUFS |-10.0 TPFS  | range 13.8 LU ) - i would like the analysis be shown not only in the commandline but in a separate (explorer)window. is decent for being batch processed.
2.i would like to be able to find the appropriate syntax for the CLI also: i did not get the point, which option should be specified for the output of the results ?
(r128gain.exe --r128-2011 --true peak PfadWavOrdner\*.wav  -->Results of analysis?
3.the resulting analysis showed a wrong prefix in my case:
FFmpeg successfully loaded
analyzing...
  [1/1] "test.686.wav": -25.3 LUFS <2.3LU>
but it should read minus 2.3 LU (referring to -23LUFS=0LU), right?
Hope you guys do not get nervous about plain simple probs,
nice work, this r128gain...
Greez Nico
  • pbelkner
Reply #469
I'm not sure what you mean. If you like to have the EBU R128 analysis from the command line you may type something like
r128gain file1.wav file2.wav file3.wav
or
r128gain infolder\*.wav
If you want to have the results saved in some file it looks like
r128gain file1.wav file2.wav file3.wav > analysis.txt
or
r128gain infolder\*.wav > analysis.txt
If you want to have the results written as REPLAYGAIN tags the corresponding commands look like
r128gain file1.wav file2.wav flac file3.wav -o outfolder flac
or
r128gain infolder\*.wav -o outfolder flac
analyzing...
It depends on the interpretation of the term "gain". The gain is the amplification which have to be applied in order to get the target loudness.
You're welcome.
  • Last Edit: 06 November, 2012, 02:27:56 AM by pbelkner
  • Stone Free
Reply #470
I still don't get what I have to do to get it to recognise AAC files with .MP4 extensions.
Do both Sox.exe and FFMPeg.exe both go in the r128-tools folder?
  • nfranzke
Reply #471
Thanks for your immediate reply, your code samples will work -
i was uncertain about the ability of r128gain to work serially, now it is self-explanatory.
or
best regards,
nfranzke
  • jangk
Reply #472
Hello,
I just tried to tag some FLAC files with R128GAIN v1.0.alpha6-4, and the program crashed repeatedly during the writing process.
It also happens with earlier versions.
I found out that it happens consequently with FLAC files with embedded album art.
Removing the album art with e.g. mp3tag solved the problem. R128GAIN wrote RG information to the tags and did not crash.
Is this a bug in R128GAIN ???
Jean
  • pbelkner
Reply #473
Sox.exe
It's not about SoX at all.
FFMPeg.exe
It's not about the FFmpeg tool itself, it's about the related DLLs:
That's right:
  • Substitute the FFmpeg DLLs from the "r128-tools" folder with their counterparts from the unpacked "bin" folder (cf. above).
  • pbelkner
Reply #474
I have to correct this a bit. In order to avoid having the "analysis.txt" spammed with the progress messages you should provide the option "--progress=off", i.e.
r128gain --progress=off file1.wav file2.wav file3.wav > analysis.txt
