Topic: Problem with decoding AAC with FAAD2 after encoding with NeroAacEnc (Read 4653 times) previous topic - next topic
  • polemon
Hi, I created some files with neroAacEnc (version 1.5.4.0) on Linux and they work fine with mplayer.
But when I want to play them with MPD, FAAD2, the decoder used in MPD for AAC decoding, reports the following error:
decoder: audio_format=44100:16:2, seekable=false
faad: error decoding AAC stream: Invalid number of channels
The file is not played, and MPD skips all AAC files in the current playlist queue.
In case this is of any importance, I created the AAC files from WAV PCM files with no extra options, so all I used was defaults.
Had anybody a similar experience?
If so, how could I circumvent that problem, apart from recompiling MPD, since it needs loads of -devel packages, that I don't feel like installing...
Distro is Fedora 14.
  • Last Edit: 04 January, 2011, 09:00:00 PM by polemon
  • kerem
I had a similar problem. Well at least I got the same error and could not find much info on forums. I was trying to decode adts aac frames using faad2 2.5 which are encoded by faac. The error message I was getting was also "Invalid number of channels". When I checked NeAACDecOpen function in decoder.c file which creates the NeAACDecHandle, I noticed that it is by default not expecting adts frames.
hDecoder->config.downMatrix = 0;
hDecoder->adts_header_present = 0;
hDecoder->adif_header_present = 0;
When I changed that to 1 for adts, decoder started to work without any problems. Make sure you are initializing it properly.
  • Last Edit: 29 December, 2011, 03:44:24 PM by db1989
