Classical music tagging
2010-12-27 04:11:44
There were threads on classical music tagging before, but I don't want to ask "how to" but rather I'd like to ask "do you see any possible problems with the tagging scheme I want to use". I thought that it would be safer to ask for input before I spend days with mp3tag. There are two reason why I want to tag or retag my classical music collection. First, tags that one gets automatically from freedb are a mess. So far I got around it with folder-based organization of music, which, with clever title formatting, worked very well in foobar. It allowed me to replicate multi-level classification of classical music, e.g. a folder cold be named "Z:\Music\Classical\#Brahms\Symphonies\4\Kleiber" and have four files with four movements of the symphony. Title formatting was used to display the path as "Brahms Symphonies 4 Kleiber". But the second reason for retagging is that I started using Sansa Fuze+, which has no folder browsing. The library uses album, artist, and title tags, and that's it. No chance to use "performer", or "composer", or "genre". So I need to come up with a tagging scheme that will provide as much information as possible in a useful way in these three tags. Here is what I am leaning towards now, please let me know what do you think, in particular, if you see any possible problems.Artist: Composer, e.g., Bach JS Album: Name of the work and name of the performer(s), depending on the type of work it could be ensamble, conductor, soloist. If the same performer recorded the piece more than once, then year follows. E.g., Johannes-Passion BWV 245 - Herreweghe 1988 or Harpsichord Conc BWV 1054 D - Musica Alta Ripa . I am not entirely sure what to do with certain multi-part works, for now I think that Brandenburg Concertos will be tagged as 6 separate works, while Die Kunst der Fuge or Das Wohltemperierte Klavier as one work.Title: Track number and movement/part name, e.g., 33 Und siehe da, der Vorhang im Tempel zerriß , or 02 Adagio e piano sempre . The track numbers are changed from CD-based to work-based. Thus, if there are two 4-movement symphonies on a CD, each will be tagged as tracks 1 to 4. Similarly, the recording of St. John's Passion I mentioned above spans two discs, with 20 tracks on CD1 and 19 tracks on CD2, but it will be tagged as tracks 1-39. I know that putting track numbers into title is redundant, but I want to be able to see the numbers on the PMP, and the track tag is not visible there. So, any comments or suggestions?
