Topic: FAAC stuff compiled in VS.NET? (Read 2382 times) previous topic - next topic
  • Tom Servo
Do you think the VS.NET C++ compiler produces better code than the VS6 one?
I did compile FAAC, IN_MP4 and IN_FAAD from Jan 25. It's Win32 code. If anyone interested tell me where to put it, so that Dolby can't fux0r me.
  • rjamorim
You should compare which one is faster decoding and encoding AAC.
If VS.NET version is faster, I would really appreciate to host the binaries at my page, if you don't mind. (Btw: all files there are compiled with VC6, in case you want to do comparisions)
Regards;
Roberto.
Get up-to-date binaries of Lame, AAC, Vorbis and much more at RareWares:
http://www.rarewares.org
  • Tom Servo
Dunno, on first thought I'd say the VS.NET compiler would spit out better code. Prob now is how to test VS6 vs VS.NET/VS7.
  • rjamorim
Just use a chronometer.
See how much time each build of FAAD takes to convert AAC -> WAV
And how much time each FAAC takes to  convert WAV -> AAC
A track of 5 minutes should be enough to notice any remarkable velocity increase.
Regards;
Roberto.
  • Tom Servo
Gonna test now.
Using that song "Fatboy Slim - Everybody needs a 303", it uses lotsa synthies, I think FAAC has lots to do. Also I'm using that cmdline:
faac -m 4 -o LTP -t -b 128000 303.wav 303.aac
Gonna reedit the post on results.
  • Trelane
Anyone that doesn't download the 21 MB worth of runtime files won't be able to run it.
