Topic: Help with script to auto-switch output device (Read 2621 times) previous topic - next topic
  • bsw11
I have been struggling with a problem of needing 2 different output devices depending on whether I am playing 2 channel or 5.1 channel sources.  After getting an update of the ASUS driver I have eliminated the need to manually switch the ASUS and now all I need is some way to detect whether the track to be played is 2 or more channels (best case) or an .mp3 or .flac (worst case because some flacs are 2 channel) and then based on that determination set the output device to the proper setting.
Can someone please point me to a plugin that would be capable of doing this and possibly a sample script to use in the process.
  • shakey_snake
  • Moderator
Well, fb2k doesn't really let you switch output devices like that.
elevatorladylevitateme
  • bsw11
That is too bad, however if there is a plugin that can cause even an external event of any kind (system call), then I can use something like audit to open the device page and arrow to the choice etc, so for openers can you tell me what plugin can detect the type of track that is playing?
Maybe if the developer or a hot plugin developer reads this, they can whip up something that will work.
  • bsw11
Progress - I have scripted autoit to change the device perfectly (2 scripts).  I have foo_run installed but I don't know how to write the script in foo_run to execute the autoit scripts which once I figure that out, I can at least have 2 different function keys setup to do a quick switch.
So my 3 issues at this point are:
1 - Figure out how to make foo_run run my Autoit scripts  (I can easily do this on a command line).
2 - Figure out how to execute a FB2K script at the start of play of each track
3 - Figure out how to test the number of channels in the track and then either execute the foo_run script or possible just execute my AutoIt scripts directly in this script thus eliminating the need for foo_run.
Any help would be greatly appreciated.
  • alkasar
I use autohotkey with this script. I run it from buttons via foo_run/
The script is a quick and dirty mod of the original ahk script published on HA originally for 0.9
it works great !
It would be great that the output device was part of the API so that dev could do that simple thing. But it seems foobar devs have always done, and continue to do what they want, not what we need.
; AutoHotkey Version: 1.x
; Language:       English
; Platform:       Win9x/NT
; Author:         A.N.Other <myemail@nowhere.com>
; save script in foobar folder as "outputSelection.ahk" or compile it as "outputSelection.exe"
; run script with foo_run
; for exemple C:\Program Files\foobar2000\output.ahk 0
; what is ending "0" ?
;   "0" is the first device output, if you want the 2nd
;   C:\Program Files\foobar2000\outputselection.ahk 2
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
    SetTitleMatchMode, 2
    IfWinExist, Preferences
        Winclose
    Run, foobar2000.exe /config
        WinWait, Preferences, , 10
    WinActivate, Preferences
    ControlFocus, SysTreeView321,Preferences
    WinGetText, win,Preferences
        IfNotInString, win, Output
            Loop
            {send o
            IfInString, win, Output
            break
ControlFocus, ComboBox1, Preferences
send, n
send, {home}
send, {Down %1%}
send, {return}
WinClose,Preferences
;Run, foobar2000.exe /stop
;Run, foobar2000.exe /play
return
  • alkasar
bring back this old question
Is there an alternative to %cwb_volume% ?
  • shakey_snake
  • Moderator
No. Presumably it's not needed any more since title formatting is mostly reserved for formatting titles now, and not scripting volume widgets.
Posts merged from unrelated topic
  • Last Edit: 17 December, 2010, 12:05:52 PM by shakey_snake
