Topic: Features (Read 2696 times) previous topic - next topic
Features
I just started trying out foobar2000 and before I really start using it and migrate away from iTunes, I was wondering if the following features were available as extensions.
- Last.fm scrobbling capability
- Media keys on the preview window in Win7
Thank you in advance for any help.
Features
Thank you for the quick reply. Do you happen to know how to configure the last.fm plug-in. Like where do I enter my account name?
And yes I was referring to the taskbar thumbnails.
Features
thank you, they both work perfectly.
Features
For the record, I prefer using the last.fm client, as it allows more fine-grained control over scrobbling behaviour, and lets you Love a track.
Features
Hi I'm new in this foobar buissness and have few questions
1 Can you rate songs like in winamp ? if no is there plugin for this ?
If there is a plugin for this or function, can you make playlist from best rated songs like in winamp ?
2 Can you import playlist from winamp using foobar ?
3 Can you enable somehow numbers showing which mp3 file you are listening (and I'm not talking about "track no" because I have mp3's that show nothing in this section and lot of them, winamp counts them so it is easier to find favourite ones etc, but foobar shows nothing in track no field (propably because they are random songs with no file info)
4 Can you change skins in foobar ?
Features
Yes. It's called foo_playcount, and will log rating as 1-5 as well as playcounts and other relevant data. Check here.
That's possible, but I don't know off the top of my head how to do it. People more familiar with library queries can help you.
Yes. Foobar can open .m3u playlists.
Note: internally, Foobar saves all open playlists in the user folder, so there is no connection between a playlist in foobar and the playlist file you just opened.
Yes. If I understand you correctly, (from memory) right-click on any column header in a playlist and enable the column that contains the playlist item number. I don't have FB handy and can't remember what it's called. Play around.
It is technically possible, but it's cumbersome, poorly supported, and the general feel is that foobar is about functionality rather than looks. It's minimized most of the time anyway. If you want more layout power, check out a component called "Columns UI", but I recommend trying out foobar in its default state first,
I strongly recommend tagging your files and making sure you keep your music files in a single location.  Many powerful organisation features of foobar depend on proper metadata.
Features
Thanks, you helkped me a lot, goodby winamp I wont miss you
