Topic: Foo dsp delta (Read 3286 times) previous topic - next topic
  • jorgen68
Foo dsp delta
i read about this interesting plugin on this page http://www.neowin.net/forum/topic/290673-n...000-plugin/.But i found out that it's not compatible with the new version of foobar.is there a new version or can somebody update this so it works with the new version?
  • tpijag
Foo dsp delta
Used noise sharpener as the terms in the search box and found the following. I believe it works just fine in the current foobar.
http://foosion.foobar2000.org/components/
  • Last Edit: 29 November, 2010, 02:34:46 PM by tpijag
  • jorgen68
Foo dsp delta
Thank you for the fast reply.it worked
