Topic: Exact Audio Copy V1.0 beta 1 (Read 37554 times) previous topic - next topic
  • greynol
  • Global Moderator
LOL.  I have a batch script that maintains entries for two versions that I typically use: V0.95 and V0.99.
I can't rip or do any stuff with the new EAC. I can't make cue files and when EAC should start ripping it just hangs and I have to restart the program. I am on Windows 7 x64 and have a "Optiarc DVD RW AD-7173A 1-04" and I use the drive profile which EAC recognizes which correct offset etc. Anyone else having the same problem? Regards
  • Agent69
Same for me on Windows 7 x86. It can play the CD and identify it but when I go to rip, it freezes.
  • greynol
  • Global Moderator
If you haven't, you should try the official forum since I don't think Andre reads this one.
What drive letter do you have associated with the drive you're trying to use to rip?
  • Last Edit: 15 December, 2010, 03:55:40 PM by greynol
I fresh installed v1.0 and set it up from scratch. Worked great and I loved the album art search and copy to the music folder feature.
No issues yet as I've only ripped a few CDs to WavPack and V1 LAME VBR. I also like the feature of advancing the track numbers on the subsequent discs so it can all be put into one play folder. I had to edit the playlist by combining the separate disc tracks in one file.
Q6600 processor, Win7 x64 Pro, 8GB of memory.
Can anyone hazard a guess as to why, even though I have "Delete WAV after compression" checked, EAC does not delete the WAVs, and furthermore, just to rub it in, gives all my flac files random 9-character filenames starting with #tmp?  (FWIW the WAVs are named perfectly)
  • trout
...EAC does not delete the WAVs, and ...gives all my flac files random 9-character filenames starting with #tmp?
One thing that will cause this is extra characters (like a space) entered at
Compression Options --- External Compression tab --- Use file extension: ________
Make sure the text box has nothing but ".flac"
  • Last Edit: 12 January, 2011, 12:43:25 AM by trout
~ Sorry for my bad english.
Reply #32
Thanks, that did the trick
  • drattz
no zip file?
  • Alexxander
Reply #34
Unpack the installable .exe file with 7zip
  • drattz
Reply #35
Which EAC.exe.manifest is installed? The new one does not have the freedb tag section.
  • MrSinatra
Reply #36
