Topic: QAAC: discussion, questions, feature requests, etc. (Read 372986 times) previous topic - next topic
  • Bostedclog
Reply #100
Before I decide to encode all of my music to qaac .Does anyone know if there will be any significant improvements in the near future regarding sound quality.Many thanks..
Sound quality is of course the same as files generated with Quicktime/iTunes directly, since qaac interfaces Apple's encoders. So you should bug Apple about their encoders if you deem them too bad. At relatively low bitrates, Quicktime was recently found to produce the highest quality AAC encodes, though.
I dont know whether my question came across wrong but I think the qtaac/qaac encoders are brilliant .I as just wondering if any big changes are expected if not Ill start encoding 11,000 tracks.
  • LigH
Reply #101
Sounds a bit like sending a letter praising the powerful engine and easily shifting gearbox to the manufacturers of the car chassis.
The author of qaac is not responsible for the quality of the AAC encoder developed for Apple QuickTime. He "only" gave you the ability to use it without the QuickTime Player application.
But I'd like to thank him a lot for this essential job, because it is a prerequisite to use it with different user interfaces.
  • Last Edit: 03 January, 2012, 05:49:44 AM by LigH
http://forum.gleitz.info - das deutsche doom9/Gleitz-Forum
  • sneaker
Reply #102
Bug report:
It seems that the "iTunSMPB" tag is written incorrectly for HE output. Instead of writing the correct delay value, it will always write the standard LC value (840).
Haven't checked padding value yet.
  • Last Edit: 06 February, 2012, 05:55:10 AM by sneaker
  • nu774
  • Developer
Reply #103
Bug report:
As far as I know, iTunes is using exactly the same value including padding.
How did you think it is incorrect?
  • sneaker
Reply #104
Bug report:
I compared the value to the actual delay that I can see in Audacity after decoding to wav.
For LC the value stored in the tag as delay is 840 which equals 2112 samples in decimal notation. The source file was 44.1 KHz.
2112/44100Hz ~= 48ms
Comparing the original source wav and the decoded wav I can see that this is correct.
Now for HE qaac also writes 840, which would mean:
2112/22050Hz ~= 96ms
But comparing the files in Audacity I can see that the actual delay is 117ms
When I encode with NeroAacEnc it will correctly adapt the value to the output profile.
  • Last Edit: 06 February, 2012, 06:53:10 AM by sneaker
  • nu774
  • Developer
Reply #105
If you think it's problem of Apple encoder, you should report this to Apple.
qaac is just using the value which obtained via CoreAudioToolbox API. Probably same for iTunes
(leading/trailing frames of AudioConverterPrimeInfo).
  • Last Edit: 06 February, 2012, 07:18:34 AM by nu774
  • sneaker
Reply #106
Sorry, I don't know what part of the work is Apple's and what is yours.
Can anyone with iTunes confirm that it has the same problem?
Another suggestion:
As the iTunes value is wrong, just write your own value. It is always fixed, isn't it? 117ms would equal "A14", roughly.
  • Last Edit: 06 February, 2012, 07:45:45 AM by sneaker
  • Alex B
Reply #107
This iTunes/QT HE issue is interesting.
In last July I helped the JRiver developers in adding support for iTunSMPB to their recently introduced new decoder: http://yabb.jriver.com/interact/index.php?topic=65076. Gapless HE and HE+PS decoding didn't initially work correctly because the doubled output sample rate was not taken into account. But this was a decoder issue, not an iTunSMPB tag issue. AFAIK, it is correct to write the tag values that work with the LC part. If a decoder creates the reconstructed higher sample rate output, it should adjust the values accordingly.
Though, I had earlier created a set of useful sample files: http://yabb.jriver.com/interact/index.php?...22862#msg422862 . In that package my iTunes encoded HE-AAC files indeed had incorrect iTunSMPB tags. I discovered that an early version of iTunes 10 didn't do this right:
From: http://yabb.jriver.com/interact/index.php?...23115#msg423115
FYI, I just noticed that the ITUNSMPB tag values in my "iTunes HE-AAC (SBR)" sample files are slightly off. This was caused by a buggy iTunes version (an early v.10 build).
I just installed the latest iTunes version (10.2.1.1) and the bug seems to be fixed. It produces values that are identical to the Nero and QuickTime values.
For encoding the "QuickTime LC-AAC" set I used the qaac frontend and it created correct ITUNSMPB tags.
So, if you are considering adding gapless support, don't use the "iTunes HE-AAC (SBR)" file set for testing the behavior.
  • Last Edit: 06 February, 2012, 12:20:16 PM by Alex B
some archived old tests: http://listening-tests.freetzi.com
  • Alex B
Reply #108
sneaker,
What decoder did you use?
Could it be possible that the decoder uses the older Nero/FAAC gapless method (and does it correctly) if that data is present, but does not interpret iTunSMPB correctly if the format is HE-AAC?
  • sneaker
Reply #109
sneaker,
I'm using the AviSynth plug-in ffmpegsource. It does not seem to read the iTunSMPB tag nor the old Nero info at all, thus is ideal for finding out the encoder delay. If it would just be an issue of not taking the halved sample rate into consideration, the delay should be off by a factor of two, which is not the case. (117ms / 2 != 96ms)
  • nu774
  • Developer
Reply #110
I confirmed your findings with avconv.
Also found:
  • Actual content seems trimmed by 20ms or so.
  • QuickTime player decodes it without leading zeros. Instead, zero padding is appended to the end. Whole length is same with avconv, and actual content is trimmed here, too. Probably it is already trimmed when it is  encoded.
When iTunSMPB says:
[blockquote]2112 + A + T (A: length of input, T: length of trailing zero)[/blockquote]Actually it looks like:
[blockquote]L + A' + T (L: actual leading delay, A': length of encoded samples, T: length of trailing zero) [/blockquote]where:
[blockquote]L ≒ 2580, A' = A - (L - 2112)[/blockquote]Note:
[blockquote]2580/22050 ≒ 0.117
(2580-2112)/22050 ≒ 0.02[/blockquote]I sent PM to squo asking about this.
  • Alex B
Reply #111
Something is definitely not right.
For a practical test, I created a short 44.1 kHz wav file. It contains 102400 samples of 8820 Hz sine wave.
I converted the sample to HE-AAC and LC-AAC with qaac. Then I decoded the resulting m4a files with foobar2000 and iTunes.
Foobar2000 produced accurate file durations for both decoded files (102400 samples), but the decoded HE sample is delayed by a bit over 20 ms.
iTunes didn't even get the durations right. The decoded LC file is 102312 samples and the decoded HE file is 103358. The latter contains a bit over 20 ms of some quieter stuff in the end (quieter by about -20 dB).
I'll upload the samples and add a link here.
EDIT
The sample package is available here:  http://www.hydrogenaudio.org/forums/index....st&p=785135
  • Last Edit: 07 February, 2012, 10:06:53 AM by Alex B
  • sneaker
Reply #112
[/list]When iTunSMPB says:
[blockquote]L ? 2580, A' = A - (L - 2112)[/blockquote]Note:
Did you swap A and T, i.e. shouldn't iTunSMPB be L + T + A(')? At least that seems to be correct in the case of LC.
  • nu774
  • Developer
Reply #113
Yes, as for iTunSMPB your order is correct. I described here in the order which appear in the actual audio stream.
Might have been misleading.
  • Xenion
Reply #114
with --concat-cuesheet foobar2000 reads the chapters perfectly but itunes does not. does itunes not support chapters?
  • nu774
  • Developer
Reply #115
If I remember correctly, iTunes was ignoring ALAC chapter before.
However, it looks like iTunes is now supporting chapter of ALAC in m4a.
In my environment (iTunes 10.5.3.3), "chapter" menu appears  when a file including chapter is being played.
  • Xenion
Reply #116
hm with aacs it works but not with alacs here (iTunes 10.5.3.3)
  • yuker
Reply #117
I've created tool for using "qaac" without installing QuickTime.
http://www.mediafire.com/?kk96ytd933bf119
  • nu774
  • Developer
Reply #118
Is this stripped version of lvqcl's package?
Eh, I see, that was on megaupload (and is already lost).
  • Soulvomit
Reply #119
Would it be possible to disable normalization when downmixing? If not, could the option be added?
Thank you, nu, for this great tool.
  • Last Edit: 22 February, 2012, 07:24:31 PM by Soulvomit
  • nu774
  • Developer
Reply #120
When you want different gain for each channel, you might surely want to disable automatic normalization of matrix coefficients.
Since automatic normalization of coefficients will be usually convenient, I will leave it as default and add another option.
  • lvqcl
  • Developer
Reply #121
My version uses 7z.exe (and 7z.dll) for unpacking and yuker's uses 7za.exe and system32\msiexec.exe (interesting idea).
Also, it seems that the biggest dll file (icudt46.dll) contains only some data for ICU library. it is possible to compile 'dummy' icudt46.dll that doesn't contain any data. This version is sufficient for qaac encoding:
[ Specified attachment is not available ]
  • Last Edit: 31 January, 2015, 05:36:37 PM by lvqcl
  • Boulder
Reply #122
I'm getting this error with qaac v1.31:
ERROR: libmp4v2: mp4v2::impl::MP4File::WriteBytes: write failed: errno: 28 (..\..\mp4v2\src\mp4file_io.cpp,163)
What does it mean? I was trying to encode a 5.1-channel DTS-HD MA track to 5.1-channel AAC using this command line:
eac3to.exe d:redline.dts stdout.wav | qaac.exe -i -N -V 82 --verbose --tmpdir d:\ - -o f:redline_audio.m4a
The error occurs always at the exact same spot.
By the way, qaac says that it's version 1.30.
  • nu774
  • Developer
Reply #123
What does it mean?
errno 28 means ENOSPC (No space left on device).
Thanks, updated files.
  • Boulder
Reply #124
Weird, there is enough space on drive F..or does it actually run out of space on drive D (tmpdir)?
  • Last Edit: 26 February, 2012, 12:37:26 PM by Boulder
