Topic: QAAC: discussion, questions, feature requests, etc. (Read 856512 times) previous topic - next topic
Re: QAAC: discussion, questions, feature requests, etc.
Reply #1225
You are amazing; I'm not installing 7zip; that is the problem. I appreciate your help.
I absolutely do not know if you now solved your problem or if that is a sarcastic note.
Reply #1226
Hi there!
Just read the whole debate on this thread about qaac inducing glitches on later versions of the CoreAudioToolbox dll.
I also saw nu774 say that afconvert doesn't produce the same issues. I just wanted to confirm that using afconvert via a macOS command line would not cause any glitching when using CBR like qaac would?
Thank you very much!
Reply #1227
I don't understand what do you mean by "confirm". If you have access to the macOS, why don't you try it yourself? Otherwise, it has nothing to do with you.
Anyway, CBR is the least interesting mode that offers literary zero advantage over others.
It's somewhat surprising that this issue attracts so much interest of someone like you.
Reply #1228
True, but there are still cases out there where hardware decoders struggle with VBR/ABR, which was the reason it eventually led me to finding this bug.
Reply #1229
I believe everyone would like to know what device(s) claim to support AAC but fail to do so. People have the right to know what products and companies to avoid.
Reply #1230
Aren't you just mixing up AAC and MP3? I get what you're saying iff it's MP3.
Reply #1231
No! Not that one! It's kinda random but I have 2 devices that generally like nothing VBR. One just takes forever to start playing the track and won't seek, and the other one will say error reading the file at the exact end of the track (also takes quite longer to start the track). But it's nobody's problem here that there are hardware implementations that are garbage. The only thing that I'm thinking about CBR and being buggy is that since the option is there, you would assume nothing is particularly broken about it, yet it is. More of an uncomfortable "woopsie" from Apple's side than anything related to QAAC as a project. Atleast I'm glad I ran across it. Atleast people now know. Still just out of curiosity I'd want to make an ABX test with the last version that didn't have that issue.
Reply #1232
Have you tried ABR on that devices?
There are only 15 allowed frame sizes (byte lengths) in MP3, and CBR in MP3 will pick only one of them.
The meaning of CBR is simple and very strict in MP3. To improve compression efficiency under such limitation, MP3 has a bit-reservoir mechanism that allows bits in one frame to be borrowed or used by other frames.
Also, MP3 is a format without container. Player should naturally struggles handling non-CBR MP3 in some way.
Nothing like that applies to AAC.
Reply #1233
I didn't realize it immediately—the possible explanation seemed too far-fetched—but I this is what I guessed .
Those broken players likely don't use the MP4 sample access/seek structures (stts/stsz/stco) at all. Instead, it reads the necessary AAC codec startup data from the esds section, and then just moves to the mdat section to sequentially read and decode frames, almost as if it were just a WAV file. Although it's not using the container's features, and thus wouldn't know the frame boundaries, decoding should still be possible—provided there aren't any other tracks in the MP4 file.
When seeking, they just calculate the byte offset from the seek point as if it were a WAV file again, and just jumps there. Of course, this only works if time and byte length are linear—that is, in the case of constant bitrate (CBR). After seeking, it would need to re-synchronize to align with the start of an AAC raw frame.
In this scenario, it doesn't need to be as strictly CBR as MP3. Apple's AAC doesn't have exactly fixed frame sizes even on CBR, but as long as the bit reservoir is used to maintain a constant bitrate over slightly longer time spans than a single frame, there shouldn't be an issue.
Reply #1234
You may be surprised how many new generation of so called "Tech" people on Github or other places suggest 7zip or WinRAR files as virus. No and I am not joking.
Reply #1235
Updated makeportable2 just now.
Now it tries to use tar.exe first, which should be present in recent Windows OS by default.
This libarchive based tar.exe supports many formats as is written here:
https://github.com/libarchive/libarchive
Reply #1236
Nu, can't you add a link to an Apple Installer that can be used? I was surprised there is none in your FAQ. I mean, if you'd just write "download file here: xyz and then use files x,y,z out of it", as a newb I'd be done in seconds.
I worked in IT (IT security, plus some Perl related projects), define as an IT guy and don't work in IT any more. And no, nothing can surprise me. Not even the incredible lack of self-awareness of many people. So many totally dumb and uneducated people out there thinking they are Einstein.
Yesterday there was a Reddit expert teaching me that the choice of codec is important! -> "Vorbis sounds bad and Opus sounds great". What am I supposed to answer? Exactly. Nothing, it's ridiculous. Let them do their thing. I'd guess 95% of all people would state "FLAC of course, no need to discuss, sounds so much better on your APT-X BT speakers than <whatever lossy codec at whatever quality>". Youtubers always say such things.
Time is crucial, I meanwhile became hesitant helping other people especially if I already know beforehand, how stupid and time consuming things will go.
Reply #1237
Anybody who has github account can edit the qaac wiki pages (it's open).
I personally find it troublesome to keep track of changes to the URLs caused by their whims, so I don't want to handle it myself.
Reply #1238
I've edited the wiki to add the url to the iTunes installer. I would hope, given the url name, that it will be a long lasting active link.
Reply #1239
Thank you. The issue lies in the fact that the download page includes several sections with download links, and when viewed on a Windows browser, a section called "show-on-microsoft-store" will be shown, which directs users to download from the Microsoft Store. However, if you install the app from the Store, it cannot be used with qaac.
There is a small "Looking for other versions?" link on the bottom of the page, and by selecting "Windows" through that link, the "show-on-microsoft-store" section is hidden, and the "show-on-windows" section appears instead. This alternative section allows you to download the traditional version of the installer (64-bit/32-bit).
This is the behavior at present so far, but explaining this process every time has been inconvenient, which is why I have been avoiding it.
Reply #1240
These
iTunesSetup.exe
iTunes64Setup.exe
work currently, but no guarantee the links won't change.
korth
Reply #1241
@nu774 - I had seen that, but failed to realise I need to more a bit more explicit. I've added the following:
NOTE: do not download the Microsoft Store versions as they will not work with qaac. Use 'other versions' linked on that page.
Thanks @korth I had seen them in that location but wanted just one url. Hopefully the note will be enough to aid people.
Reply #1242
May I ask, what about Apple Music? I've installed Store version of apple music on win11, navigated to its folder via task manager ("open [exe] file location"), and copied the required dll's from there, and they seem to work the same as those QTfiles from github link.
Also I'm glad that Foobar can just use qaac64 even if it is itself 32-bit, or if qaac is installed system wide, it can use that.
And I really appreciate such detailed info on qaac wiki tab!
Reply #1243
I.e. you can create m4a files? Then that's fine. The Tools field in fb2k metadata will reveal the CoreAudio which has been used (eg "qaac 2.83, CoreAudioToolbox 7.10.9.0, AAC-LC Encoder, TVBR q91, Quality 96")
Reply #1244
Yeah, both from fb2k and directly through commandline. Super happy that with libFLAC it can take in flac files and even keep tags/cover.
Oh yes, thanks. It's all the same except qaac 2.84. I suppose since CoreAudio hasn't changed sirca 2017 it's all the same.
Reply #1245
@nu744 - Hi, a few questions here or maybe a wish list:
- converting to mono - using the --matrix-preset switch (is there another way?), works great but throws a stop error ('ERROR: unmatch number of channels with matrix') if the input is already mono. It would be great if the switch gets ignored in such cases.
- sample rate conversion - when it's a set numbers, an option to always reduce the sample rate when the input rate is higher, but never to increase it when the input rate is lower
- automatic output file name generation - can the --fname-format switch use the input file name as a tag (sort of like ${filename} )?
Reply #1246
Probably you want to just throw multiple files to qaac using a single command line (maybe a batch) without much care?
Sounds reasonable, but this will only increase valid input channel layouts from one to two. You cannot handle both of strereo and surround this way.
Also, one annoying point gets in the way: you usually want to also apply --gain or --normalize after --matrix-preset (since it makes output attenuated), but when mono->mono was pass-through you don't want to change gain, aren't you?
Similar motivation as above?
No reason to object regarding this.
I can say for sure that this is not that useful.
Filename should already be in your hand, which you could cook in many possible way in shell: https://www.gnu.org/software/bash/manual/html_node/Shell-Parameter-Expansion.html
You may just want to remove file extension, or you may want to capitalize, or you may want to convert underscores to spaces.
Whole lots of possibilities which is way over what should be done as a audio encoder's responsibility.
You could just iterate over files with shell loop, cook filename as you like on the shell side, then pass it using "-o" option (without --fname-format).
Reply #1247
Yes, its for a batch file processing. For me, the above points require ffprobe and qaac to be run on each input file individually instead of running only qaac with a wildcard multiple file input.
Reply #1248
@nu774
why your amazing encoder not support flac to wav encoding? need flac to wav, then wav to m4a ...
Reply #1249
I assume you mean direct conversion flac to m4a as below.
but qaac don't support direct conversion flac to m4a.
Did you read the manual?
Quote from: Installation
libFLAC version 1.2.1 and greater are compatible with qaac; the win64 bundle should be used with qaac64 and the win32 bundle should be used with qaac. Extract libFLAC.dll from the archive into the same directory as qaac. qaac will look for libFLAC with any of the following names: libFLAC_dynamic.dll, libFLAC.dll, or LibFLAC-8.dll.
korth
