Topic: Tagging box sets - how to? (Read 3764 times) previous topic - next topic
  • exec
I recently stumbled upon a problem when tagging box sets: how to preserve the info that this CD is part of a box set?
When a box set contains CDs which were not released seperately, then this is not a problem, because the disc titles would be "<name of boxset> - Disc 1", etc. But what to do when the box set contains only CDs which were released seperately (e.g. the Black Sabbath "Rules of Hell" box)? I'm using FLAC and can't see an applicable tag which I could use here. The best solution thus far is just using the 'comment' tag ("Part of XY box set").
But isn't there a better solution? Any ideas?
  • Roseval
If your media player supports it, you can use DISC NUMBER
If not you can renumber like 101,102 etc , 201,202, etc
I have used MP3Tag to do so.
http://thewelltemperedcomputer.com/SW/MultiVolume.htm
TheWellTemperedComputer.com
  • Teknojnky
I subscribe to the 'keep it simple' principle:
Rules of Hell (disc 1: Heaven and Hell)
Rules of Hell (disc 2: Mob Rules)
Rules of Hell (disc 3: Live Evil 1)
Rules of Hell (disc 4: Live Evil 2)
Rules of Hell (disc 5: Dehumanizer)
Rules of Hell (disc 6: Live at Hammersmith Odeon)
Last.FM Nodes for your library @ http://build.last.fm/item/356
  • exec
Keeping it simple is ok, but...
In this example, I'll get one problem: "Live Evil" is a double disc album. I'll tag such an album "<album title> - Disc X". You can't do this with the tagging style above, otherwise you'll get something really weird.
However, I consider these discs to be albums on their own. So in this case I would not tag these files with the box set name. Only the info that these discs were part of a box set should not be "lost".
  • BoraBora
Actually, CDs which were released only in a box set may have each  a title, like James Brown's "Star Time" 4 CDs box set (CD 1 : "Mr. Dynamite", CD 2 : "The Hardest Working Man in Show Business" etc.). Even an original multiple album may have a title for each CD, like Kate Bush "Aerial" (CD 1 is "A Sea of Honey", CD 2 is "A Sky of Honey"). And you may even stumble on an album from the vinyl age where each side of the original LP has a specific title.
If you wish to preserve all these titles and don't want to mix different kind of informations in the same tag, you'll have to create your own fields. This is allowed by FLAC's Vorbis comments. I use a DISCTITLE field, a SIDETITLE field, and in answer to your question a BOX field when every dic in the box has been previously released with its own title. So if I owned this box, it would go like this:
Disc 1:
BOX = Rules of Hell
ALBUM =  Heaven and Hell
etc.
But it's up to you to choose you own custom fields. Obviously, you probably won't be able to read them on a portable player (or any half-baked PC player, for that matter) but you'll be fine with the likes of Foobar, MediaMonkey etc.
  • Teknojnky
erm, I am not sure how you consider it can't be done, look closely again.
keeping it simple as my example allows everything work correctly in any type of player that can read/display/scroll the album tag
  • SmashCan
I use the album and comment tags in this situation. I don't use disc #s unless one of the albums spans 2 discs.
Album: Please Please Me [2009 Stereo Remaster]
Comment: 2009 Stereo Remastered Box Set
I use iTunes and create a smart playlist to isolate the box set. You can sort by comment or grouping as well, but the albums can't be displayed in order of year like the smart playlist.
