Topic: foo_vst: VST 2.4 adapter (Read 537763 times) previous topic - next topic
Reply #100
Hi
I use portable mode. My Foobar (newest stable Version) crashes an launching with the newest version enabled.
Cheers
Alex
Reply #101
Oops. Sorry. Download the 0.7.1.
Reply #102
It seems like you did something and the click when closing VST config window rarely happens now.
Reply #103
It doesn't click on focus loss anymore, closing procedures all remain the same. But I admit it could affect closing as well.
Reply #104
There's a change to the worse from 0.60 to 0.71 with two plugins I tried (Melda Dynamics and Multiband Dynamics): When foobar is playing, the configuration window is blank (i.e. 100% grey), the content only shows when the music is stopped. Other plugins work.
I am using a rather slow laptop, so it might be a task priority problem - but this didn't happen in 0.60. I am using the portable mode. Since I deleted the older dll, I cannot investigate the problem any further.
Reply #105
I confirm this with a difference that it randomly occurs in both versions. Got to dedicate time for that later. The performance should not be a problem. v0.6 is attached to the post.
Reply #106
Hi
fantastic, it works now and in the meantime it even is gapless.  Great.
Thank you very much.
Reply #107
I verified it with the old version, too, and you're correct: There was no regression. In fact another component I forgot I changed was eating the cpu time. No big deal since I spotted it, thx again.
But as the last point on your to-do list there might be a possibility to boost the priority of the VST plugin, for everyting else in the playback chain there seems to be an option under Preferences->Playback->Thread priority.
Reply #108
This is only done for batch processing (like replaygain scanner and converter), not for DSP components.
Reply #109
I just upgraded from 1.00.01 to 0.71 so thanks for this nice plug and thanks now it looks like its working great in portable mode.
But I also get the problem where the configuration window is blank (i.e. 100% grey). It's like that all the time music playing or not with HDPHX crossfeed... http://refinedaudiometrics.com/products-hdphx.shtml
Reply #110
HDPHX does not have any configuration so you get that, just close the window.
Reply #111
Failed to load DLL: foo_vst.dll
he asked what library ? no dependency requirer in wiki
thank you
win XP, foobar 1.1.1
edit: Microsoft Visual C++ 2008 Redistributable Package (x86) was the problem , please add in wiki
Music is my first love.
Reply #112
OK.
0.8.0
The adapter has been rewritten from scratch with considerable changes concerning VST plug-in handling.
The [un]loading strategy was completely changed, so now core VST DSPs are always kept active starting with the fb2k at once.
There is no “idle timer” anymore and the corresponding advanced setting has been removed.
FXP loading/saving has been fixed.
Some dirty and unsafe tricks were removed in order to increase stability and reliability, so VST settings won't be saved with a editor left opened on quit.
Important note: To get your VST entries back in the normal (non-portable) mode, you should click Add... button in the preferences holding the Shift key. The registry won't be used to store VSTs anymore.
Reply #113
FYI, HDPHX crashed again when accessing its configuration. Can you disable configuration for this kind of VST plug-in, one that doesn't have a real configuration?
Reply #114
HDPHX crashed again
No crashes here.
@Entrase: What are "core VST DSPs"?
There is still the problem of thread safety. When converting more than one file at once and having the converter thread count not limited to 1 the resulting files are garbled.
Reply #115
Yes, it does not crash normally, unless you try to access its configuration.
Reply #116
Ok, here is 0.8.0.1
No crashes here.
It does crash if you try to open HDPHX config in 0.8.0.
VSTs in the main DSP chain (as opposed to secondary chains in the “convert” feature). I'm used to name them so after get_core_settings()
Confirmed. I'll investigate this as soon as possible.
UPD Oh my... This seems to be a major problem. I've never tested it that way. If the player recalls same dsp_preset data objects as in case of conversion then all the same vst instances are used to process different audio streams. Damn. I don't even know what to do.
UPD2 Nevermind that pang now. Gotta try a solution later. Hancoque, thank you for pointing that out.
Reply #117
Yirkha, who took over the development of the Dolby Headphone wrapper some time ago, made it thread-safe which it previously wasn't. Maybe he can help you there.
Reply #118
It's not really about thread safety (there is all wrong in a one thread as well). It's about coupling back fb2k's decoupled approach to DSP settings setup. I mistakenly assumed that adding some random data to preset objects would allow me to identify different instances of VSTs. But I missed that these randomized presets could be recalled in more than one processing chain. Hence one instance of a VST plug-in can be assigned to more than one DSP processing object, which is way wrong because such VST will process chunks from different streams by turns and that's where garbling goes on.
Reply #119
That's fast. Thanks.
Reply #120
It seems that every plug from the ReaPlugs pack works fine, except for ReaComp. After adding it to the VST Plugins list, foobar just crashes. However, it runs fine if you run it in Acon Effectchainer.  crash report
EngineersFilter has a strange bug in which the right channel gets stuck on a loop after a few seconds of using it. It just repeats the few hundred samples over and over until you take it off.
Both of the plugins are free, so go ahead and try them yourself. I forgot to backup my vst collection a few weeks ago, so I'll keep testing them as I get them.
Thanks a ton for all your effort, this will certainly get some use from me.
Makes my stuff redundant but oh well
Not really, your plugins are native whereas these are not. 'nuff said.
Reply #121
except for ReaComp
Confirmed and fixed. It requests UID for null instance and that's strange from my point of view. I didn't expect such behavior.
It sticks on declicking procedure. I'll try to find out why. Now you can disable declicker by setting its size to zero: Preferences > Advanced > VST > Declicker size. Restart is required.
Please let me know if you need the fixed version now. Otherwise the bugfix is due to the next release.
Reply #122
Hi!
I found your plugin excellent for using vst-plugins.    Although It doesn't work under "wine". Do you know any procedure to make it work under it. I'm using OSX Snow Leopard, a portable installation of foobar v1.1.1, Isone Pro, some freebie plugins and Reaper for testing (where I can use the plugins normally).
I'm using v0.8.0.1 of your plugin, and after installing it and launching foobar, I get this message:
Reason: Unknown error code (317)
and in the terminal the message is:
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.VC90.CRT" (9.0.21022.8)
wine: Call from 0x7b829da2 to unimplemented function msvcr90.dll._set_abort_behavior, abortingfixme:msvcr90:__clean_type_info_names_internal (0x78506644) stub
fixme:ntdll:RtlNtStatusToDosErrorNoTeb no mapping for 80000100
fixme:win:RegisterShellHookWindow (0x10052): stub
fixme:keyboard:RegisterHotKey (0x100e0,0,0x00000006,46): stub
I tried downloading and registering the "msvcr90.dll", though I'm not sure if it's the correct version, or if I'm putting where is supposed to go (Windows\system32) ? or skipping some important step.
Any help would be very apreciated, as with it I could use my phones and Isone Pro to listen music as it should sound, as I do with my windows and linux PC.
RoKK
Reply #123
Is there anything like this to check the version?
I have Ubuntu installed in VirtualBox. I'll try it there but, speaking frankly, I don't know much about other systems, so you may have to wait.
UPD: Fixed.
Reply #124
In ubuntu work after install vcrun2008 with winetricks.
