Topic: foobar reset everything (Read 3200 times) previous topic - next topic
i was short of eletricity and my PC was off. after i put it on foobar spitted up two errors(that he cant recognize last arrangements)
it reset my skin, my playlist. EVERYTHING. i dont have my buttons icons tho
how can i get this back? i dont think so if it got deleted
Power loss can result in data corruption in any software. Your data is lost. You have two options to prevent this in the future: Buy a UPS to avoid power loss until you can shut things down, and/or use foo_jesus to automatically backup your config on a regular basis.
If you are using the a good enough version of Windows, you might have success with the "Previous Versions" feature.
it says there is no previous versions
well then i leave it
i think these hours what i would spent on makin my foobar so cute as it was i use to learn linux and deinstall this wack OS from my pc
A complete foobar configuration comprises multiple files, including the playlists, prefs, databases, components. Are they all lost?
i got everything exept my custom made
