Topic: AudioCoding MP4 winamp plugin (Read 4870 times) previous topic - next topic
  • Tom Servo
Just wanted to tell you that it crashes with an access violation when trying to run it on a multiprocessor. I had to "imagecfg -u winamp.exe", so that it runs on one CPU only to get it working (setting affinity in the taskmgr everytime sucks  ). You should check that sometime.
Cheers
(Hope this was the right forum)
--edit--
Forgot to mention... the normal FAAD winamp plugin works fine in on multiprocessor.
  • rjamorim
To tel you the truth, the right forum would be audiocoding's own forum
http://www.audiocoding.com/phorum/list.php?f=1
But that's OK...
http://www.rarewares.org
  • menno
  • Developer (Donating)
Could you ty again with the latest code in CVS?
I think it should work fine now.
Menno
  • Tom Servo
oke, gonna install CVS then and try it out.
what compiler do i need? i'm running VS.NET since a week, so i dont know if it will work 100% in there.
  • menno
Never tried that
MSVC and Intel CPP compiler work ine
Menno
  • Tom Servo
Where is the CVS? Either i'm blind or there is no info on your homepage. :confused:
  • menno
http://www.sf.net/projects/faac
You should be able to find it there. It can also be found on the development page of http://www.audiocoding.com
Menno
