Topic: Can't open Flac CUE file (Read 8339 times) previous topic - next topic
I have correctly encoded single flac with cue file.
I have APE plugin in component folder
I can open single flac file
I can't open cue with separate tracks
Got this error mesage
Unable to open item for playback (Object not found):
"C:\Documents and Settings\Signe\Desktop\Torrent\Dhomont\Francis Dhomont - Sous le regard d'un soleil noir.cue" / index: 1
What is wrong with my foobar 2000?
copy and paste the text in the cue file using the
[codebox][/codebox]
tags
Object not found errors and the last track not reporting a length means the referenced file is missing. There also appear to be foreign characters in your CUE sheet's file name, so make sure your CUE sheet is UTF-8 encoded with Notepad or any other Unicode capable text editor, with Byte Order Marker.
[codebox][/codebox]
tags
this is how I place the code in cue file, but does not help
REM DISCID 680C1708
REM COMMENT "ExactAudioCopy v0.99pb5"
PERFORMER "Francis Dhomont"
TITLE "Sous le regard d'un soleil noir"
FILE "Francis Dhomont - Sous le regard d'un soleil noir.wav" WAVE
  TRACK 01 AUDIO
    TITLE "Pareil  un voyageur perdu"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Engloutissement"
    INDEX 00 07:58:44
    INDEX 01 08:00:50
  TRACK 03 AUDIO
    TITLE "Arr te! Arr te! Elle me tue"
    INDEX 00 15:52:59
    INDEX 01 15:55:05
  TRACK 04 AUDIO
    TITLE "Implosion"
    INDEX 00 23:17:21
    INDEX 01 23:20:25
  TRACK 05 AUDIO
    TITLE "Le moi divis "
    INDEX 00 27:34:21
    INDEX 01 27:35:05
  TRACK 06 AUDIO
    TITLE "Citadelle int rieure"
    INDEX 00 33:59:11
    INDEX 01 34:05:02
  TRACK 07 AUDIO
    TITLE "P trification"
    INDEX 00 41:45:17
    INDEX 01 41:49:52
  TRACK 08 AUDIO
    TITLE "Le message quand vient le soir"
    INDEX 00 47:08:51
    INDEX 01 47:14:62
if the "referenced file" is "text file" I have it and saved as UTF-8
This is the line that shows the cue which file to reference:
It should be:
FILE "Francis Dhomont - Sous le regard d'un soleil noir.flac" WAVE
elevatorladylevitateme
It should be:
Ok, right.
-Thanks -
Also, chiming in with a useless report that I thought I saw a lower case E with an accent mark over it, and I was mistaken. Whoops, more obvious error that could have been solved if I'd noticed you were already asked to post the CUE file. Moo.
