Topic: Tag view for Logitech MX5500 keyboard LCD (Read 5853 times) previous topic - next topic
Any working plugin for Logitech MX5500 keyboard LCD display?
foo_winamp_spam.dll & foo_logitech_lcd_0_5_3 not compatible...
P.S. SetPoint 6 (logitech software) + Windows Media Players = works great. May be any WMP API emulator plugin will help?
I posted a working hack in the other foo_logitech_lcd thead by using foo_winamp_spam and renaming foobar.exe to winamp.exe, but this seems to have been depreciated since 1.0
Yep, renaming foobar2000.exe to winamp.exe on 1.x version leads to error.
May be it is possible to edit SetPoint settings, so it could check foobar2000.exe? On player.ini there is a line:
WinAmp5=cmd,winamp.exe,Winamp v1.x,xxx,xxx,40045,40046,40047,40044,40048,0,1,WinAmp 5
but changing it to something like this has no effect:
WinAmp5=cmd,foobar2000.exe,[foobar2000 v1.1],Winamp v1.x,xxx,xxx,40045,40046,40047,40044,40048,0,1,WinAmp 5
Should be just like this, I guess:
[font= "Courier New"]WinAmp5=cmd,foobar2000.exe,Winamp v1.x,xxx,xxx,40045,40046,40047,40044,40048,0,1,WinAmp 5[/font]
The fake Winamp window still has the window class "Winamp v1.x".
This players.ini hack won't help here  SetPoint 6.15.6, foobar2000 1.1.1, foo_winamp_spam 0.96.
Any other options to try? WMP & Winamp both works like a charm
i have a solution. I'm using plugin foo_winamp_ipc.dll and create portable foobar in VMware ThinApp and rename foobar2000 to winamp. This work perfectly.
Sory for my english
