Topic: Help installing foobar skin! (Read 13002 times) previous topic - next topic
First of all, I have search and understand the general idea. I know that components go to components folder, as well with the PanelsUI and fonts. But even when I do this, I cannot get any of the 4 skins I tried to work. Perhaps they are outdated since they were made years ago and there are new versions of fb2k out.
So then I went ahead and copied the component, fonts and PUI to their directories. When I open fb2k, it prompts me to select my interface module, where I select "Panels UI."
After that, I get this error:
The following components are incompatible with this foobar2000 version and will function partially or incorrectly:
- foo_ui_panels.dll : Panels UI
Please update these components to their latest versions if possible.
Failed to load DLL: foo_ui_columns.dll
Reason: Wrong version number; this component appears to have been built with an outdated version of the foobar2000 SDK and needs to be recompiled with newer version in order to load; please contact the author of this component to obtain an updated version of this component.
I also had a problem with this tech skin:
http://br3tt.deviantart.com/gallery/#/d2ovre0
Yet there is NO components, fonts, PUI files in that zip/rar file. So where am I supposed to get those files?
Ive also ran into problems where I copy and paste the components/fonts/PUI files to their directories, then start fb2k and it does NOT tell me I have a new interface modules. I go to preferences and there is no Panels UI option even after I copy and pasted all of the correct files.
WTF!!! this is so confusing especially since im a pretty computer savvy guy
  • tpijag
Panels UI is no longer supported and has not been for quite a while.
Regarding the tech skin...support is best asked at deviantart art.
terry
terry
I already did. In fact I posted on 3 or 4 different boards but still have not found help.
fail
  • lvqcl
You can download old versions of foobar2000 here:
http://www.videohelp.com/tools/foobar2000/old-versions
http://www.filehippo.com/download_foobar2000/history/
Id rather just stick to the newest version so do you know where I can find UPDATED skins?
Also seems that the TECH skin posted in the OP was update for the new fb2k. I cannot  however figure out how to install it.
  • Last Edit: 09 October, 2010, 05:27:07 PM by donttrip619
  • lvqcl
Ask author(s) of these skins.
But installation process is described on the TECH 1.4 web page.
  • NEMO7538
Some of the components are outdated and buggy.
Directions say to install fonts, components, configurations etc into the directories. Yet I cannot find these fonts/components/config files in the zip/rar file I downloaded from that page. Included in the zip file: tech1.4.fcl, images, scripts, changelog.txt, readme,txt. OK, so where are the fonts/components/config files??? lol
  • jazzthieve
You are barking up the wrong tree here, as tpijag already said you'd best ask support on deviantart on Br3tt's deviantart page for Tech.
  • herojoker
On the theme's page you can find:
Requirements:
- Fonts: [link]
- Components: [link]
- Configuration files: [link]
- Images + .fcl file : [link]
- seekbar.fx file for Wave Seekbar : [link]
The links lead you to the files, which you have to download.
  • Last Edit: 09 October, 2010, 06:32:26 PM by herojoker
Thanks, I thought everything was placed conveniently in a zip file as it usually is.
Finally able to get it to work!
  • Last Edit: 12 October, 2010, 06:49:07 PM by Yirkha
