Topic: Wavpack Lossy Quality (Read 44412 times) previous topic - next topic
I note that a certain pet bird has the signature line
WavPack (352/448 kbps) lossy for HQ lossy encodings and transcoding
LAME 3.90.2 (by Dibrom) --alt-preset extreme -Z --lowpass 21 or --alt-preset insane --lowpass 21 for my mp3s
MP2 384 kbps stereo for the classical music on my portable
MusePack 1.15r --insane --xlevel for archiving on CDs
Is he right in using WavPack, as opposed to MPC?
Something tells me the higher the bitrate, the more he likes it - There isn't an MP2 encoder as well tuned as Lame, and cranking the bitrate up to 384 isnt going to make the encoder more 'tuned'. And MPC insane / MP3 APX are virtually unnecessary overkills too; YMMV.
Lev:
Hahaha... you are very, but very witty pet. Why not trying it yourself? And almost everybody knows that in such high bitrates is LAME no rival for MP2, even if it's not "so tuned". Guess, what is a basis for MPC?
I don't know - what MP2 encoder do you use and what is the typical music style?
The fact that MP2 is the basis for MPC means as much as BladeEnc does for MP3 quality.
I have some opinions about the rest of that signature, but I'll keep those to myself.
First of all a lowpass at 21KHz is insane. Most modern cd players cut at 20KHz and only a few people can hear a difference with a lowpass at 16KHz. The normal lowpass the presets use should be safe enough.
Secondly. Do you consider wavpacks lossy mode to be of a higher quality than mpc? I don't think even the author of wavpack would agree.
Last but not least I would like to see an mp2 encoder that can outperform LAME. Though it shouldn't be impossble I certainly have not heard about such an encoder.
To the claim that mp2 should be good because mpc is I can only say that that is really a flawed argument. Is xing good because LAME is relatively good? MPC is way beyond what mp2 ever was/is.
edit: ok, after search this board it seems that wavplack lossy mode is actually quite good at that high bitrate and a competitor to mpc (though mpc would use a lower bitrate).
Very original, I don't ever recall some one starting a thread over a member's signature. It will be interesting to see the results MPC+WPL ABX testing.  It really annoys me to see: LAME 3.90.2 (by Dibrom) should be 3.90.2 compiled by Dibrom or credit all the lame developers.
HA History X.
Edit: Interesting, Garf edited his post without a "This post has been edited"
--ARE safe.  Its not the lack of High Freq. which lets MP3 down, its the constraints of the format, and resulting smear / pre-echo (which will worsen with upped lowpass).  [Luckily, I dont find these annoying]
Where can I get a Wavpack Encoder / Decoder / Plugin?  (Yes, I know, UTFS, sorry)
Whats the general consensus for quality?
If this is the standings at the moment:
1. MPC
2. AAC [span style='font-size:8pt;line-height:100%'](dont understand the differences between all the different implementations / versions / modes, so sorry if its unfeasible just to write 'AAC')[/span]
3. OGG
4. MP3
Where would WavPack lossy show up?  1.5, 2.5, 3.5 or 5
[span style='font-size:8pt;line-height:100%']Edit: I've just realised this is liable to generate a huge number of responses from people defending their preferred formats.  Can we just stick to the positioning of Wavpack, please
Thanks[/span]
That is default for all moderators I think. There's a checkbox I have to explicitly tick off if I want the 'has been edited' stuff to show up, which I generally won't think about when I fix a small typo or clarification immediately after posting.
--Will be provided, probably not over the extreme drinking binge known as Easter
Most modern crappy-shitty CD players maybe cut at 20 kHz, but not a decent one. Every CD player worth its name has frequency range at least 20-22050 Hz. When is this insane, why AAC/MPC encode at full bandwidth? (Not the standard settings). Ogg also encodes far beyond 21 kHz  So it's no insanity.
WavPack lossy mode at this bitrates is for me definitely better than MPC. Although it doesn't mean MPC is wrong or of insufficient quality. My reasons were stated here http://www.hydrogenaudio.org/forums/index....&f=1&t=8280&hl=
As for the author of WavPack... I think no developer of any codec would express to the another codec in terms of quality. So we should leave it on their decision. But I personally believe the WavPack author knows his codec is of very high quality, no doubt about it.
MP2 was designed for high bitrates, whereas MP3 not. That's why (but not due to this only fact) it sounds good at these bitrates. This is from one of my PMs I got:
MP2 really rules above ~250kbps, indeed. About the same thing as musepack ~180kbps.
If the author allows me it, I will reveal his name.
Excuse me, sir, I really didn't want to offend your feelings...  Already corrected to your satisfaction, I hope so...
--bah..  You ^might^ be able to hear a 22khz tone, but unless it was just that tone at high intensity and nothing else, you wouldnt hear it in music.  No chance.
[span style='font-size:8pt;line-height:100%']Edit: Sorry, thats over the top, but its well natured, done with a smile and not intending to offend (and its funny)[/span]
The issue is far more complicated than this, in a so much that I wouldn't dare to do a statement who is right here.
Last I looked, MPC at standard level was lowpassing at 20kHz. Ogg at standard level is below that even. The most aggressive modes are called 'insane' and 'braindead' for a reason.
What I read from that is that WavPack is better for you because it gives you the warm fuzzy feeling (even though you admit MPC is tranparent for you).
What??
This is true. It in no way invalidates the points that were made.
I've asked you about the encoder and settings you use. You didn't respond. Please do.
Specifically:
Once the quality exceeds what can be measured in ABX tests, I suspect that most of the people at HA would say that all codecs are the same, but I don't believe that. There is no doubt that WavPack's lossy mode provides better quality than other lossy codecs above some bitrate because it provides a straight line to lossless encoding which the others do not.
There are no logical grounds for either statement.
Dear Lev, it really doesn't matter, if you can hear it or not. Or do you think all the developers of these codecs are stupids who don't know what they are doing? Also all the CD players' manufacturers? Or those who record and mix the CDs? Why was SACD or DVD-A developed? Just for the fun of it? This matter was discussed here many a time, I guess. Stop repeat BS you read here and there on the HA and really learn something about the matter. It would really help you, believe me.
--  It aint all BS on here!
I'll provide some FLACs for you to ABX next week ref: lowpass @ 20khz
[span style='font-size:8pt;line-height:100%']Edit:  Noticed this
... Ummm, I think of them as Gods to be quite honest, thats why they lowpass in the first place![/span]
See my statement about default MPC and Vorbis lowpass. I did part of the work in tuning Vorbis for high bitrates and I can tell you that the sole reason the highpass is gone in higher quality modes is to prevent people like you from bitching that it lowpasses (since the bitrate cost is negligible, a tradeoff I gladly make).
If you load in a Vorbis file, even encoded at high bitrates, you'll see it'll almost never goes over +- 19kHz.
Some CD's are pre-lowpased at 20kHz. Don't find them much anymore, but then again, not lowpassing fits in with the trend to compress all dynamics out of them I guess.
To push DRM.
[/qoute]
I couldn't have said it better, why don't you do this?
Garf:
If you read carefully, I wrote (Not in the standard settings).
That's your interpretation. I never said anything like that. I mentioned spatial resolution, no "warm fuzzy feeling".
You can find it on Roberto's site. Everything else is in my sig.
I tested a lot with Vorbis 1.0 at -q4 and the frequency response war up to 21,3 kHz...
A lot more isn't. No reason for doing it.
To push DRM.
I simply don't believe this is the only reason. It gonna get cracked as everything else.
Just because you are one of the few people here I respect for their work, I won't react to this...
MPC is designed to be transparent at the standard setting. It lowpasses at 20kHz. What does that tell you? I expained you the reasons why Vorbis doesn't. APS also has a lowpass (though there are other pressing reasons in MP3).
If you cannot ABX a difference, all that's left is placebo. Hence a 'warm fuzzy feeling' is the only difference, except that you're calling it 'improved spacial resolution.'
I hope it gets cracked. But they put CSS on DVD's too. But you are right, another good reason is that they can 'sell people new expensive equipment'. (Those are Frank Klemms words)
I've happily flamed  Dibrom, JohnV, Monty and David Robinson in the past, so please don't spare me your sound reasoned out arguments, I don't deserve it.
Vorbis 1.0 lowpasses at 20.5kHz at quality 4, and the default quality is 3 IIRC.
(I'm guessing the higher freq you see is actually a compression artifact, or a bad spectrum analyzer)
Companies are in business to make money
[span style='font-size:8pt;line-height:100%']Edit:Actually, I dunno.  I need to read up[/span]
I may be wrong but doesn't SACD & DVD-A allow easier mastering & not allow clipping & compression? Error correction would be much better than current CDDA also surround sound support but obviously they are not compelling enough for general users to switch.
And better spatial restitution (multichannel)
It's not about capabilities - CDDA has those as well, at best it's slightly harder for stupid mastering engineers to shoot themselves in the foot. The only 'advantage' is that early on there will be incentive to properly master SACD/DVDA (and make even worse CDDA) to demonstrate the 'advantages' of the new formats.
You can make shit hot SACD and DVDA without dynamics as well, I'm sure it wont take long before they are commonplace as well.
Is it of any significance? Many CDDA's nowadays have crippled error correction for 'copy protection'.
Ok, maybe a small advantage
True, but with DRM integrated into the disc format, we can have our error correction back.    :duck n' run:
And don't forget about possibility to once again sell people all those albums they already bought (already more than once in some cases). It's easy once you make them belive that new format sounds much better.
I wonder how long we'll wait for format that "breaks through some significiant limitations" of DVD-A/SACD
