Topic: How to make Wavpack/FLAC file burn to CD directly by EAC? (Read 6596 times) previous topic - next topic
  • DOSforever
Is it possible?
  • Apesbrain
Yes, it is possible if you created a CUE sheet when you ripped the files:
http://blowfish.be/eac/Burn/burn.html
If you just want to burn some audio tracks to a CD-R, you may want to use Burrrn!
I noted in another thread that you tried and failed at burning with foobar2000.  I suggest you update to latest version of foobar and try again.  No reason it shouldn't work.
  • greynol
  • Global Moderator
No, it is not possible for EAC to burn wavpack or flac directly.
AFAIK, the only lossless format that EAC can handle is Monkey's Audio.
  • Last Edit: 04 October, 2010, 01:40:40 PM by greynol
I know you're looking for a "direct" method through EAC, but the easiest way is to just decompress the compressed/lossless files to WAV and then burn with the EAC writer. Just delete the WAV files when you're done.
I find the CD-Writer in EAC to be very good and useful IMO. You can use the free version of dBpoweramp to decompress to WAV. (It's not multi-threaded like the paid version but it won't matter as it only uses one thread to decompress files to WAV anyway.)
If you've created a cue sheet in EAC with multiple WAV files/noncompliant then everything should just work. It's a lot easier than I've made it sound.
The Loudness War is over. Now it's a hopeless occupation.
