Topic: Will a speaker magnet damage CDs/DVDs? (Read 13574 times) previous topic - next topic
In my new apt my CD towers sit right next to my floorstanding Paradigm speakers. Will the speaker magnet damage the CDs?
No.
If you believe too much of what you read in the high end audio press (e.g. Stereophile) then you might think so.
Back in the real world - please see pdq's post.
No, magnets affect magnetic media only. CDs are optical media and aren't susceptible to magnetic damage.
Well, you could take apart the speakers and bash the CD's with the tweeter magnet.  I suppose that might damage them a bit.
But just sitting next to speakers certainly won't hurt them even if they are unshielded speakers.  Most speakers today are constructed so that the magnet fields are cancelled very close to the actual magnets anyway.  Very strong magnetic fields can harm a CRT monitor and so these days the fields are blocked or cancelled out by most recently made speakers.  But no magnetic field from even an unshielded speaker will be anything like strong enough to affect a CD in any way.
Ed
Ed Seedhouse
VA7SDH
How strong is strong enough?  Remember, the metal in CDs is typically aluminum or gold.
I am not aware that they are alloyed with ferrous material.
I think I'm going to do a "Glock Torture-Test" on a CD I don't care about.
The first phase of my test will be to leave a high-powered magnet on the CD for about a week. I'm going to predict that the disc won't be KIA until I get to the part where I skip it across my driveway a few times.
The Loudness War is over. Now it's a hopeless occupation.
I have access to a 3-Tesla MRI scanner. If I don't forget, and if scanner operators allow me to do so, I can put a CD in the bore, and check later if it still plays ;-)
Ceterum censeo, there should be an "%is_stop_after_current%".
Stereophile mag and sites arent reliable?
I think in the interests of HA you need to do that
Unless you allow the CD to remain in there until the point the aluminum warps from the heat (or delaminates from the plastic due to differential expansion) I would expect no harm... and would that even happen if you keep the radio off?
Creature of habit.
Strong enough to suck steel objects across the room to smash the CD.  That can happen with the MRI scenario.
Is that a question or a statement?
The "?" suggests it was a question. The answer probably is "Yes" with them writing the following about powerline accessories:
House current can be notoriously dirty. Treat your system by cleaning up your AC.
A stopped clock is accurate twice a day...
Not on a moving plane.  Ergo, some audio magazines are only right when the watch and the plane are broken.
But both watches and planes are sensitive to magnetic fields.  Ergo, do not put either next to your speakers.
But CDs will be fine - can't say the same for the brains of some "audiophiles."
If you spun the CD for a sustained period really close to a very powerful magnet the induced eddy currents in the aluminum layer might cause enough heating to damage the disk.
If such a thing existed here, I would nominate odigg's post for "Post of the Week".
This thread was worth it for this post alone. I needed the laugh.
Thanks for the input guys. I didn't think it would be a problem - just wanted to be sure. Unpacked my albums only to discover that I need not one but 2 new 7' towers for the albums I've bought lately.
It's a bad habit. Good to know the discs are safe.
