Topic: foo_mircnp (Read 4003 times) previous topic - next topic
foo_mircnp
http://mudlord.info/crap/audio/foo_mircnp.zip (binaries)
Source is in my GitHub.
This was done entirely as a exercise in WTL usage. Should be useful for component devs as a general component code example.
the mIRC component supports spamming with title format syntax, so the output format is easily configurable. The component does *not* require outside dependancies like mIRC scripts or extra mIRC addons.
Please note this component is not really supported, and just uploaded as a service for FB2K component devs.
foo_mircnp
Failed to load DLL: foo_mircnp.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000.
Which runtime is it depended on?
foo_mircnp
MSVC2010
foo_mircnp
Because the component does not use a addon for mIRC, thats impossible.
I prefer if the design is kept as is. The source is there though, so people are welcome to mangle it so it does.
Or...If you are referring to the titleformat settings, they do exist. They should be in the "Display" tab of the Preference system.
foo_mircnp
Uploaded new build since old link was broken.
