Topic: foo_stopafteralbum.dll (Read 50980 times) previous topic - next topic
  • grimes
  • Developer
Stop after album
Works with CUI/DUI
actual version: 3.6
Usage:
Menu | Playback | Control | Stop after album (ON/OFF)
Menu | Playback | Control | Stop after last track (ON/OFF)
Menu | Playback | Control | Stop after album & last track (ON/OFF)
Menu | Playback | Control | Repeat album (ON/OFF)
Menu | Playback | Control | Skip album once (ON/OFF)
Menu | Playback | Control | Random album track (ON/OFF)
Menu | Playback | Control | Repeat current track once (ON/OFF)
Menu | Playback | Control | Skip next track once (ON/OFF)
Menu | Playback | Control | Reverse (ON/OFF)
Menu | Playback | Control | Previous playlist (ON/OFF)
Menu | Playback | Control | Next playlist (ON/OFF)
Menu | Playback | Control | Repeat playlist once (ON/OFF)
Menu | Playback | Control | Gap tracks | 5s - 1h (ON/OFF)
Menu | Playback | Control | Gap albums | 5s - 1h (ON/OFF)
Menu | Playback | Control | Stop after albums once | 1 - 10 (ON/OFF)
Menu | Playback | Control | Stop after tracks once | 1 - 20 (ON/OFF)
Menu | Playback | Control | Alarm | 5s - 5h (ON/OFF)
Menu | Playback | Control | Timebomb | 0.5h - 5h (ON/OFF)
Advanced Preferences | Playback | Stop after album (OPTION/MODE)
Comments:
Stop after album: TRACKNUMBER = TOTALTRACKS
Stop after last track: create field name LASTTRACK with field value 1
[ Specified attachment is not available ] [ Specified attachment is not available ]
  • Last Edit: 23 August, 2013, 04:32:00 AM by grimes
  • grimes
  • Developer
msvcr100.dll dependency removed
  • Last Edit: 20 September, 2010, 05:49:34 PM by grimes
  • grimes
  • Developer
Stop after album v0.2
ADD: Stop after current after x albuns
ADD: Stop after current after x tracks
ADD: Stop after current after x minutes (based on tracklength sum)
  • grimes
  • Developer
Stop after album v0.3
FIX: minor bugs
ADD: allow using album/time/track simultaneously
  • grimes
  • Developer
Stop after album v0.4
RMV: Only stop once (general)
ADD: Only stop once individually for Album/Track/Time mode
ADD: Timebomb mode (simple timer firing stop after current)
ADD: Gap (stop after current -> stop -> gap (default: 10s) -> start next track)
  • Last Edit: 27 September, 2010, 08:23:20 AM by grimes
  • grimes
  • Developer
Stop after Album v0.5
ADD: Paused (stop after current->stop->(gap)->next track paused)
ADD: Repeat album (album stop after current->stop->(gap)->album is repeated) (experimental)
  • Last Edit: 28 September, 2010, 04:45:10 AM by grimes
  • grimes
  • Developer
Stop after album v0.6
ADD: Tracknumber mode
ADD: Skip album option
Note: Please read Preferences | Components | Stop after album | About | Usage
Please report bugs/crashes/feature requests in 3rd party thread.
  • grimes
  • Developer
Stop after album v0.7
FIX: several bugs
ADD: option presets for modes
  • grimes
  • Developer
Stop after album v0.8
ADD: most common presets as menu commands (Repeat album. Skip album, Gap album)
  • grimes
  • Developer
Stop after album v0.9 "official release"
  • grimes
  • Developer
Stop after album v1.0
FIX: reset when stopping
FIX: Timebomb not working
ADD: Timebomb message popup
ADD: Repeat current once (menu)
ADD: Skip next once (menu)
ADD: Gap (every track) (menu)
CHG: component on/off in Advanced Preferences
FIX: minor bugs
  • Last Edit: 05 October, 2010, 04:56:27 AM by grimes
  • grimes
  • Developer
Stop after album v1.1
ADD: Random album
  • Last Edit: 11 October, 2010, 09:27:10 AM by grimes
  • grimes
  • Developer
Stop after album v1.2
ADD: (main menu command) Timebomb 0.5h-5h
  • Last Edit: 16 April, 2012, 08:18:01 AM by grimes
  • grimes
  • Developer
Stop after album 1.3
CHG: mainmenu commands moved to submenu "Control"
ADD: Menu | Playback | Control | Stop after albums | 1 - 10
ADD: Menu | Playback | Control | Stop after tracks | 1 - 20
  • grimes
  • Developer
Stop after album 1.4
FIX: "Stop after album" command (bug introduced in 1.3)
ADD: Menu | Playback | Control | Reverse (ON/OFF)
  • Last Edit: 20 January, 2011, 12:45:53 PM by grimes
  • grimes
  • Developer
Stop after album 1.5
Maintenance release
several improvements
  • grimes
  • Developer
Stop after album 1.6
Bugfix release
Code optimization
  • grimes
  • Developer
Stop after album 1.7
FIX: bug in "Repeat album" cutting of beginning of first track
CHG: Skip album -> Skip album once
  • pIv
When I check  "Control-Stop after track- Number" my foobar don't stop after playing "Number" tracks.
If I check "Control-Stop after album" and when tracknumber=totaltrack  then foobar stop.
Explain to me how to stop playing through the N tracks. I use last version of plugin - 1.7.
I solve problem. I use "playlist attributes - remove played tracks". When I uncheck this future foobar stop after N tracks normally.
  • Last Edit: 27 January, 2011, 08:58:01 AM by pIv
  • grimes
  • Developer
Stop after album 1.8
FIX: "Repeat current once" not reseted properly
Discussion thread: http://www.hydrogenaudio.org/forums/index....showtopic=83748
  • Last Edit: 29 January, 2011, 06:50:25 AM by grimes
  • grimes
  • Developer
Stop after album 1.9
FIX: "Stop playback after current track" option in (Playback) Preferences is now working, when Stop after album component is inactive
(thanks for reporting romor)
  • grimes
  • Developer
Stop after album 2.0
RMV: Preset options removed, because of minor usefulness
  • grimes
  • Developer
Stop after album 2.1
RMV: enable/disable component (in Advanced Preferences)
CHG: Compiled with SDK 2011-03-11
foobar2000 v1.1 or newer required to run components made with this SDK.
  • Last Edit: 02 April, 2011, 02:42:24 AM by grimes
  • grimes
  • Developer
Stop after album 2.2
ADD: (mainmenu) | Playback | Control |  Stop after last track
How the new feature works:
Tracks with a special tag trigger "Stop after current".
Add a new tag to the chosen track(s), enable "Stop after last track" and the playback stops after this "marked" track(s).
How to add the new tag:
  • Mark and rightclick your chosen track(s) in playlist
  • Properties | Tools | Add new field...
  • Insert field name "LASTTRACK" with field value "1"
  • grimes
  • Developer
Stop after album 2.3
FIX: bug in stop after last track
ADD: (mainmenu) | Playback | Control | Stop after album & last track
CHG: More verbose description of some commands in statusbar
