Topic: dBpoweramp Release 14 (Read 54937 times) previous topic - next topic
  • Xenion
Reply #50
is dbpoweramp able to do the following thing:
rip audio cd to an image, encode it to wavpack with embedded cuesheet and log and put a album art in the same folder (or embed it also)?
  • spoon
  • Administrator
Reply #51
YES
Yes
No
Yes
  • spoon
  • Administrator
Reply #52
R14.1 is currently in beta testing:
http://forum.dbpoweramp.com/showthread.php...8204#post108204
Of interest are:
CD Ripper: New option to set a maximum file size in KB, defaults to 256KB
AccurateRip.dll v4 (collates disc TOCs)
CD Ripper shows AccurateRip matches from other pressings in the log, upto 6 matches
CD ripper can now show AccurateRip 6 matches for a given track, using different pressings and v1 or v2 CRCs
  • GHammer
Reply #53
Of interest are:
256K ?
  • Eli
Reply #54
I think this is for the image/album art size, though not clear in what spoon wrote
  • eahm
Reply #55
Release 14.3
mp3 able to read / write v2.4 tags
mp3 decoder faster at decoding
mp3 Lame updated to 3.99.5
Versions for bundled codecs linked to dBpoweramp release
dbshell and other shell DLLs - code signed
mp3 Lame possible to supply custom extra cli values, also displays on advanced the final cli
FLAC defaults to not map Comment, Conductor, also new TRACKTOTAL and DISCTOTAL tags are written
FLAC better handles custom multiple item tag values
AIFF able to decode id3v2.4 tags
CD Ripper - prevent auto run removed in Windows 7 (not needed any more as cds are not autorun by default)
m4a Codec updated, Apple open source codec, improved iTunes tagging
Bug Fixes
CD Ripper - code to stop multiple access to drive query at same time
CD Ripper - correct musicbrainz ngs mapping ' to '
mp3 decoder could lockup with corrupted streams
AIFF tag reading (if tag was smaller than chunk)
Fixed issue causing BSOD on systems with Intel Storage Matrix driver installed (actually is a bug in Intels driver...)
64 bit tag editor, if file cannot be written then says so
Configuration Property Handler, it was still changing the explorer tag pane for disabled extensions
Great software, thanks Spoon.
  • Batman321
Reply #56
After the 21 day trial period dBpoweramp becomes totally unusable or does it keep some free basic functions?
  • marc2003
Reply #57
