Topic: Lossy.Wav Help (Read 4271 times) previous topic - next topic
Lossy.Wav Help
I need the parameters for lossy.wav to use in foobar 2000 because im getting errors and i need help setting it up correctly.....
This is the error i get:
1 out of 1 tracks converted with major problems.
Source: "C:\Users\Owner\Desktop\My New Music\09 - Pantera - Planet Caravan.flac"
  An error occurred while writing to file (Could not start commandline encoder: Access is denied.  ) : "C:\Users\Owner\Documents\Music\Planet Caravan.lossy.wv"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "C:\"Program Files"\lossyWAV.exe" /d /c c:\"program files"\bin\lossywav - --standard --silent --stdout|c:\"program files"\bin\wavpack -hm --blocksize=512 --merge-blocks -i - "Planet Caravan.lossy.wv"
Working folder: C:\Users\Owner\Documents\Music\
  Conversion failed: Could not start commandline encoder: Access is denied.
  • Last Edit: 10 September, 2010, 08:32:32 PM by Native_Soulja
  • carpman
Lossy.Wav Help
There's certainly a problem with this line:
You're telling foobar2000 to look in two places for lossyWAV at once:
Replace:
with:
/d /c C:\"Program Files"\lossywav - --standard --silent --stdout|
From the wiki:
Encoder: C:\Windows\System32\cmd.exe
Extension : lossy.wv
Parameters: /d /c C:\"Program Files"\bin\lossywav - --standard --silent --stdout|
            C:\"Program Files"\bin\wavpack -hm --blocksize=512 --merge-blocks -i - %d
Format is : lossless or hybrid
Highest BPS mode supported: 24
C.
PC = TAK + LossyWAV  ::  Portable = Lame MP3
  • lvqcl
Lossy.Wav Help
By the way, flac -5 usually compresses lossywav'ed files better than wavpack.
Lossy.Wav Help
I dont know im wrong but im still getting errors with the foobar 2k so what would be the correct parameters for me?
here is what i get:
Source: "C:\Users\Owner\Documents\Music\Ratha Be Ya Nigga (feat. Richie Rich).wv"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\Owner\Documents\Music\Ratha Be Ya Nigga (feat. Richie Rich).lossy.wv"
Command line: "C:\Windows\System32\cmd.exe" /d /c C:\"Program Files"\lossywav - --standard --silent --stdout|-hm --blocksize=512 --merge-blocks -i - "Ratha Be Ya Nigga (feat. Richie Rich).lossy.wv"
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
  • Nick.C
Lossy.Wav Help
There should be a pointer to the Wavpack executable after "--stdout|" and before "-hm" - at the moment there is no reference to Wavpack!
