Topic: TLEN - XLD (Read 4172 times) previous topic - next topic
TLEN - XLD
The latest version of XLD has added a option to the Lame MP3 encoder  "Append a TLEN (track Length) tag" it is turned on by default after some searching i really can't find out what it's for.
Wondering if someone could provide some info on it.
  • Last Edit: 07 September, 2010, 03:25:29 PM by Billytheonion
  • db1989
  • Global Moderator
TLEN - XLD
It appears to be required for Windows/WMP and probably other applications to report the correct track length. Refs from a forum Google search for "MP3 TLEN":
* http://www.hydrogenaudio.org/forums/index....showtopic=57142
* http://www.hydrogenaudio.org/forums/index....showtopic=56751
Also: According to the ID3v2.4.0 frame reference, and logically enough, it enables seektables and thus better seeking in VBR files:
Audio seek point index
  Audio files with variable bit rates are intrinsically difficult to
  deal with in the case of seeking within the file. The ASPI frame
  makes seeking easier by providing a list a seek points within the
  audio file. The seek points are a fractional offset within the audio
  data, providing a starting point from which to find an appropriate
  point to start decoding. The presence of an ASPI frame requires the
  existence of a TLEN frame, indicating the duration of the file in
  milliseconds.
  • Last Edit: 07 September, 2010, 03:35:38 PM by dv1989
TLEN - XLD
So it seems it will do no harm leaving it on.
