Topic: FLAC plugin bug (Read 2969 times) previous topic - next topic
  • Moguta
FLAC plugin bug
When I am encoding with the command-line FLAC encoder, the FLAC plugin (1.1.0 for WinAmp 2) returns "Error while stopping decoding thread" at the end of playing any FLAC file.  (Meaning I have FLAC encoding & WinAmp decoding a different FLAC file, at the same time.)
I hadn't thought that the command-line encoder would interfere with the WinAmp plugin, but it appears otherwise, oddly.
  • X-Fixer
FLAC plugin bug
for me, it's hard to believe that such effect exists. (I mean just running flac and winamp2 plug-in at the same time should work fine). may be it's because you are changing files being played or something?
  • Morphix
FLAC plugin bug
Here is what you do:
1. Find an old power supply from a pc that is no longer used.
2. Lay your current computer on its side on a flat surface.
3. Grab the power supply by the wires and wave it over the pc.
4. Jazz up this procedure like you are a voodoo doctor holding a shrunken head.
Proud member of the FLAC and MPC evangelism
  • Moguta
FLAC plugin bug
Hrm.  I can't get it to reproduce the happening.
I was encoding some files into FLAC with Multi Frontend, and whenever a track changed or stopped in WinAmp the plugin would display the error.
It hasn't happened since... even while using FLAC & Multi Frontend.
  • Moguta
FLAC plugin bug
Actually, it hasn't happened since becase I've been using your plugin instead, X-Fixer.  =p
But I think I found it isn't FLAC directly.  I'm able to encode FLAC command-line with no problems, but when I convert from one format to another (APE->FLAC for example) using Multi Frontend, it displays the error upon trying to change tracks in WinAmp.  (I loaded up the 1.1.0 plugin again)
I'm even MORE baffled about how Multi Frontend could be conflicting with the plugin... but as I said, your custom plugin (with ReplayGain info) doesn't have a problem.
  • Last Edit: 14 April, 2003, 07:39:38 PM by Moguta
  • Morphix
FLAC plugin bug
I just archived 85 cd's using flac....and playing back using x-fixer's plugin. Not once did it give me any problems. I am however using a ICL6 compiled flac binary, with speeks multienc frontend.  You really are barking up the wrong tree here, the processes don't share the same memory space so there is no way in hellz bellz this could happen.
  • Annuka
FLAC plugin bug
It is very likely you have a hardware problem. I know this sounds strange - your computer has probably been running perfectly for a long time. I have however experienced this myself - see old post link below.
Be very happy (thank X-fixer) that the Winamp plugin stops playback with a decode error. The old 1.04 plugin ignored errors and just output crap to your speakers.
See this old post for more.
  • X-Fixer
FLAC plugin bug
in fact, it only ignored "lost sync" errors (and does the same now, when option is unchecked).
