Topic: How to delete a album art cover (Read 2431 times) previous topic - next topic
  • Dot
Hello!
I found some mp3s with embedded album art. I want to delete the embedded cover. Unfortunatelly, right clicking on the cover gives no option such as "Delete cover". Is there a way to delete the cover?
  • jazzthieve
Foobar can't help you with that, I use MP3tag do delete embedded covers.
  • kabuki
I'm not sure you can do that in foobar (other might say yes and give you steps), but you can very easily done that with MP3tag
edit: 2min of retard  But twice answer better than none!
  • Last Edit: 29 July, 2010, 08:56:35 AM by kabuki
  • marc2003
i think you can in a aroundabout kind of way. open the properties of the affected files. highlight all the names/values and right click>copy (this copies all the tags to the windows clipboard). now click tools>remove tags. accept the warning dialog. now right click anywhere in the properties area and select "paste fields" and that will put all your tags back in place.
maybe you should copy a few files and test first just to be on the safe side.
  • Last Edit: 29 July, 2010, 09:02:29 AM by marc2003
  • Dot
This works, thanks a lot.
Maybe I post this as a suggestion in the development corner...
  • Zarggg
foobar2000 was never really intended to handle embedding images. I'd be surprised if they added this feature. (And am perfectly happy without it.)
  • Yirkha
  • Moderator
There is API in the SDK for manipulating embedded images (add/remove) as well as reading them, but it's apparently really implemented by the standard input for MP4-based formats only and nobody uses it as far as I know.
  • southisup
Ah, a bright coloured fish!
I'd be surprised if foobar2000 doesn't support embedded art in the long run. It's part of the ID3 spec & foobar seems to gravitate towards full (& strict) compliance with specs. But I wouldn't expect it anytime soon - there's quite a lot more to the spec than just one image.
  • jonpb
I think this is a good suggestion, since fb2k has a great tag editing interface already and embedded images seems to be now quite normal for the file formats I use anyways (i.e. flac and mp3).
  • BlueSauce
MP3Tag can delete embedded albumart.
Wait... really?  I've been dying for this feature since I first started using foobar.  It's the entire reason I still have Mp3tag installed.  Can someone with experience in making components please consider making a component that adds this feature?  I'd just like two simple context menu commands to "Embed Album Art..." (and allow the user to browse for and select an image file) and "Remove Album Art".  I had no idea this functionality was available in the SDK.
  • db1989
  • Global Moderator
And is mentioned in the first reply.
