Topic: EAC vs CueTools/CueRipper (Read 15261 times) previous topic - next topic
  • Recusant
I'm curious to know what people choose to use to rip CDs to FLAC.
I'm new to both so i'm open to peoples views.
  • Last Edit: 06 July, 2010, 06:23:54 AM by Recusant
  • danc6433
I use dbPoweramp and find it work's great, but it is not free.
EAC seems to be very popular on this site as well. I believe that one is free.
There are other options available but those seem to be the two most popular.
Both those include accrate rip which is a program that lets you know your rip was successful.
Make sure whichever program you go with it includes that.
  • greynol
  • Global Moderator
I'll use whatever gets the job done.  It's usually EAC but for tracks it cannot rip accurately I'll give dBpoweramp a shot (and/or other drives).  Occasionally this will make a difference.  I've heard enough good things about CueRipper to give it a try next time EAC can't get the job done.
There are still other options for secure ripping in Windows: foobar2000, CDex, Easy CD-DA Extractor and PlexTools (if you have a Plextor drive), and others.
For Mac, solutions include Rip and XLD.  Linux has a few solutions based around cdparanoia.
The great thing about choices is that you don't have to use just one.
  • Guiny
I've been lurking around and decided to make attempts with fbk2 and CUETools.
Does any of you use CUETools? I downloaded the program and there are 2 .exe in their folder to perform rip's: CUETools.exe and CUERipper.exe but, since I'm very dumb (or very old?) , I could not figure out which one I should use....
  • kisli
CueTool.exe is splitter, converter, verifier, etc.
CueRipper.exe is the ripper.
  • Guiny
You stand correct. What I mean is that ripping can be done through both .exe's. Through CueRipper.exe, the interface is very simple and there are no submenus to configure. Through CueTools.exe there are some settings submenus.
Possibly, and here is the thing I don't have a clue, CueRipper.exe is called when ripping through CueTools.exe. But are the settings from CueTools.exe used if ripping through CueRipper.exe? Will it use some "default" regardless of what has been set previously on CueTools?(such as the way one wishes a cue sheet to appended/created etc)
  • Last Edit: 17 July, 2010, 11:01:20 AM by Guiny
  • EricPost
I used the guide to EAC from this site's Wiki.
The thing I like about EAC is if you get a good rip, it IS a good rip. And if it's bad it tells you where exactly it's bad. I have ripped my 500 CDs with EAC and only a few of them took awhile. One took 30 minutes to rip with EAC, I don't know why it the T&C was perfect as was the Accurip. But most are fairly quick.
If you have a new CD straight out the box, I would use dbPoweramp or another ripper.
Oddly enough if I have a scratched cd and I want to try to get an acceptable rip from it, I found Audiograbber works the best. I got if from a post on here
http://www.hydrogenaudio.org/forums/index....hl=audiograbber
I wouldn't make audiograbber my first or even second choice by any means but I really have gotten a decent rip from scratched CDs using it, while all the other rippers I tried failed. You might want to give it a shot if all else fails
  • kisli
What I mean is that ripping can be done through both .exe's...
This is news to me. And since I can't get it to work, I can't really help you, I've got files, but no metainfo. Ripper settings seem to have reverted to default ones, settings for path, cue format and compression are CueTools'.
CUERipper v2.0.9 Copyright © 2008-10 Gregory S. Chudov
EAC extraction logfile from 19. July 2010, 10:50
Used drive  : Optiarc DVD RW AD-5200A  Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
     Track |  Start  |  Length  | Start sector | End sector
       1  |  0:00.00 |  6:00.73 |        0    |    27072
       2  |  6:00.73 |  6:13.72 |    27073    |    55119
       3  | 12:14.70 |  8:02.44 |    55120    |    91313
       4  | 20:17.39 |  8:48.68 |    91314    |  130981
       5  | 29:06.32 |  6:20.44 |    130982    |  159525
       6  | 35:27.01 |  8:40.58 |    159526    |  198583
       7  | 44:07.59 | 15:03.30 |    198584    |  266338
       8  | 59:11.14 |  3:57.44 |    266339    |  284157
Track  1
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\01. %title%.wav
     Pre-gap length  0:00:02.00
     Peak level 98.8 %
     Track quality 100.0 %
     Test CRC 3E57FFA6
     Copy CRC 3E57FFA6
     Accurately ripped (confidence 8)  [BF7D9B4F]
     Copy OK
Track  2
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\02. %title%.wav
     Peak level 99.7 %
     Test CRC 5A0D8566
     Copy CRC 5A0D8566
     Accurately ripped (confidence 8)  [44D37ABD]
     Copy OK
Track  3
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\03. %title%.wav
     Peak level 99.7 %
     Test CRC 63D41327
     Copy CRC 63D41327
     Accurately ripped (confidence 8)  [BFB1DBF2]
     Copy OK
Track  4
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\04. %title%.wav
     Peak level 98.8 %
     Test CRC 4595202D
     Copy CRC 4595202D
     Accurately ripped (confidence 8)  [014D4E73]
     Copy OK
Track  5
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\05. %title%.wav
     Peak level 97.9 %
     Test CRC 8561985F
     Copy CRC 8561985F
     Accurately ripped (confidence 8)  [F156A23D]
     Copy OK
Track  6
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\06. %title%.wav
     Peak level 99.7 %
     Test CRC 2959D907
     Copy CRC 2959D907
     Accurately ripped (confidence 8)  [9AA219E7]
     Copy OK
Track  7
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\07. %title%.wav
     Peak level 98.8 %
     Test CRC 12CFE48E
     Copy CRC 12CFE48E
     Accurately ripped (confidence 7)  [FAE32D22]
     Copy OK
Track  8
     Filename D:\MyDocs\My Music\Converted\Unknown Artist\Unknown Title\08. %title%.wav
     Peak level 99.7 %
     Test CRC B792FD50
     Copy CRC B792FD50
     Accurately ripped (confidence 7)  [6339246E]
     Copy OK
All tracks accurately ripped
No errors occurred
End of status report
I've send a PM to developer, he'll shed some light on it.
  • Last Edit: 19 July, 2010, 04:55:37 AM by kisli
  • greynol
  • Global Moderator
Actually it's been very well documented that EAC can tell you that there are no errors when there really are.
You didn't provide us any data to assess your conclusion, let alone tell us how you conducted your test or what the metrics were.
