Topic: Tremor issues (Read 2938 times) previous topic - next topic
Tremor issues
I was able to get vobis tremor checkout from the tree. I am running it on visual studio.
The compilation went properly.
I am running into an issue as the output seems to be not correct and is not playble.
As suggsted in the file initialization.html i did the changes to make the code take input from FILE.
I think i made the mistake somewhere as when i dumped the output it shows me only four three kinds of bytes
eith 80 , 7F , FF, 00  in the whole file. This is supposed to be the PCM output file.
The input is playable by other OGG players faithfully.
I am running the code on Visual studio 2005 .
The code has not been changed except to take FILE reading as binary as passed as input . I have used simple fopen.
I would appreciate if somebody can tell me where i am going wrong.
thanks,
Tremor issues
BTW i am using the code from main branch http://svn.xiph.org/trunk/Tremor/
  • saratoga
Tremor issues
Did you get it to work without your modifications?
Tremor issues
Well, i have only changed the code to take input from file which is working fine as the vorbis is able to read the file and extract what it needs faithfully but still the output is not correct.
  • john33
Tremor issues
Your easiest option would be to use the standard oggdec and make the changes necessary to compile against the Tremor libs. I did this about 8 years ago, but I don't think much has changed at least as far as the API is concerned.
John
My compiles and utilities are at http://www.rarewares.org/
  • saratoga
Tremor issues
So you didn't test the original code to see if it was being compiled correctly?  I would start with that . . .
