Topic: TTA multiplatform library v2.0 beta (Read 3952 times) previous topic - next topic
  • ald
TTA multiplatform library 2.0 beta released, with simple console frontend included in package. TTA multiplatform library provides: Easily integration; minimal system requirements; clean and highly optimized code; faster operations. This library can be compiled on various hardware platforms with different hardware abilities.
Download source code: http://prdownloads.sourceforge.net/tta/lib...rc.zip?download
Project site: http://en.true-audio.com/
  • Last Edit: 21 June, 2010, 09:55:44 PM by greynol
Hello. Thanks for new version.
I have first bug-report: when I encode using "-" as input file (foobar2000 1.0.3), foobar2000 reports incorrect length for output file - 6:45:47.887 (1073741823 samples) for ANY track!
with %s it's ok
  • ald
with %s it's ok
Hi, It's not a TTA bug. TTA console frontend requires correct length in WAV header on input.
So it is foobar2000 bug?? o_O But why it works fine with other command-line encoders like FLAC, TAK?
  • ald
It's not a bug, but only foobar2000 developers can help you to resolve this problem.
TTA2 will support stream with unknown length in header. TTA1 will never support such mode.
Best wishes ))
  • greynol
  • Global Moderator
Replies stemming from Steve Forte Rio's question moved here:
http://www.hydrogenaudio.org/forums/index....showtopic=81759
  • lvqcl
me thinks that the question was related to command-line encoder, not to fb2k plugin (decoder).
btw, 1073741823 samples is 0xFFFFFFFF/4.
  • greynol
  • Global Moderator
My mistake.  They've been moved back.
  • Last Edit: 02 July, 2010, 02:06:10 PM by greynol
