Topic: Error with the compiling foo_sample (Read 3395 times) previous topic - next topic
  • wahaha99
I am trying to use VS 2008 to compile foo_sample and get many errors...
like this:
error LNK2001: unresolved external symbol  "public: static struct _GUID const contextmenu_groups::root" (?root@contextmenu_groups@@2U_GUID@@B)   contextmenu.obj   foo_sample
(Anothers are LNK2019)
I dont know how to fix it...
Please tell me if you can. Thanks.
Visual Studio 2008 + WTL 8.0 + Windows XP SP3 + .NET framework 3.5 SP1
  • aganders3
Try out Zao's advice from this post:
http://www.hydrogenaudio.org/forums/index....st&p=644614
It could also be helpful if you posted the full output of the build log.
like this:
Make sure that you have built each library it needs to link to individually before building foo_sample.
They are listed in the sdk-readme.
For each project that it links to add the Library folder as an included depency path in the foo_sample project and add the libary name to the list of dependencies to use.
That is,
Build these included projects:
foobar2000_SDK project
foobar2000_component_client
foobar2000_SDK_helpers
foobar2000_ATL_helpers
Add these libraries to Additional Dependencies under project->properties->linker->Input:
shared.lib;pfc.lib;foobar2000_SDK.lib;foobar2000_component_client.lib;foobar2000_sdk_helpers.lib;
Add your library folders where these are located (whatever the output of the VS build) to project->properties->linker->general->Additional Library Directories. For me it looks like this:
G:\Documents\Visual Studio 2012\foobar\foobar2000\shared\;G:\Documents\Visual Studio 2012\foobar\pfc\Debug\; G:\Documents\Visual Studio 2012\foobar\foobar2000\SDK\Debug\;G:\Documents\Visual Studio 2012\foobar\foobar2000\foobar2000_component_client\Debug\;G:\Documents\Visual Studio 2012\foobar\foobar2000\helpers\Debug\
