Topic: Bose Staff Advice (Read 5741 times) previous topic - next topic
  • matteo1983
Bose Staff Advice
Im in the market for a new digital amplifier for the following devices - XBOX 360, Virgin + HD, PS3, PC (via HDMI), so yesterday I went to the Bose shop in Brentwood (England!) to see what they had...
The main 'audio device' on display was an amp with no buttons/display, that had 3 HDMI connections (1 out, 2 in) plus about 3 component inputs and optical inputs...
After realising there would not be enough HDMI inputs, I spoke to the sales rep, who I quote said 'plug the xbox 360 in via component and optical for BETTER sound than with HDMI as HDMI carries 3 signals for video and 2 for sound'...
Im not claiming to be technical, but that kinda goes against everything I ahve learnt so far...or am I missing something??
thanks,
Matt
  • Notat
Bose Staff Advice
Retail salespeople are not to be trusted on technical matters.
Component is analog video, HDMI is digital video. Component video is sometimes easier to work with than HDMI but it is not better.
HDMI carries up to 8 channels of uncompressed audio. Optical supports only two channels.
  • greynol
  • Global Moderator
Bose Staff Advice
That my very meager 5.1 system appears to work correctly must only be an illusion.
  • matteo1983
Bose Staff Advice
Thanks for the replies, I did actually mutter something like 'oh and I bet you recommend monster cable', not sure if he heard me though...
ta,
Matt
  • me7
Bose Staff Advice
Give him a break. He was talking about uncompressed audio channels.
  • greynol
  • Global Moderator
Bose Staff Advice
That's fine.  Thank you for pointing that out.
Bose Staff Advice
As far as the Xbox 360 goes, you really have no benefit in transmitting audio via HDMI over digital optical audio unless you are playing back an HD-DVD movie.  Games are still limited to either PCM stereo or Dolby Digital 5.1 and that can all be transmitted just fine over digital optical.  The only benefit that HDMI has with the Xbox 360 is that the console can transmit Dolby Digital Plus only with that connection (you also need a receiver that can decode said audio through HDMI).  Digital optical audio won't be any better than HDMI but, unless you have an HD-DVD drive, it will provide the same results.  The use of component video is highly questionable though.  The Xbox 360 has the ability to upscale DVDs only if either VGA or HDMI are used, otherwise DVDs will playback at a maximum of 480p.  That and spare official Xbox 360 component cables are rather expensive.  You can pick up a 3-5ft HDMI cable for less than $5.
Bose Staff Advice
Toslink optical supports 5.1 compressed channels via dolby digital and 8 uncompresed channels record/play via ADAT format.
  • andy o
Bose Staff Advice
Don't Bose only sell overpriced home-theaters-in-a-box though, if you want a receiver? I mean, you can't buy only the receiver. In any case, Bose is always behind the curve regarding the latest (and even relatively old) features. You can get much cheaper, better and MUCH more feature-packed receivers from the likes of Pioneer (my first choice), Onkyo, Denon, etc.
  • Last Edit: 27 July, 2010, 03:23:06 AM by andy o
  • spoon
  • Administrator
Bose Staff Advice
Bose? this is fairly humorous:
http://www.youtube.com/watch?v=ZCBe7-6rw4M
