Topic: TagBox Tag Editing Plugin (Read 155544 times) previous topic - next topic
Re: TagBox Tag Editing Plugin
Reply #275
TagBox 0.221 (2023-09-13)
foobar2000 v2.1 preview 2023-08-28 64-bit, DIUI, TagBox Panel
foobar2000 after restart.
The following files were corrupted after editing.
All other configuration files are also corrupted.
foobar has been initialized.
Media Library
(library-v2.0)
Playlist
(playlists-v2.0)
Theme (DUI)
(theme.fth)
etc ....
crash reports (failure_0000000x.txt) is not created.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #276
I created a portable install of foobar2000-x64_v2.1_preview_2023-08-28 adding just tagbox 0.221, and I've been randomly editing the tags of a handful of albums I copied and haven't been able to produce a crash. Are you on Win 11 as there was another post with similar problems on Win11.
It might be worth trying a portable install with just tagbox to see if it's a conflict with another component, if you haven't done so already.
Reply #277
Yes, I'm using Windows 11.
Completely restored from backup.
I reinstalled TagBox 0.221
No problem after editing in Preferences
Components.txt
https://mega.nz/file/FPlFwSCC#FAZYV5ZlmmtLxXlaQuAHIPseoEF_Ydx3dKYTTofChS8
Preferences > Tools > Tagging > TagBox
I changed the order or edited the TAG to something different.
But it is not reflected in Panel.
What is the Panel for?
Reply #278
Apply Button partially fixed with 0.221, see attached screenshot
Reply #279
No dark mode, why?
Reply #280
If you're using TagBox as a panel (rather than viewing by right clicking) then you need to perfom the configuration in the panel itself (bottom right).
Reply #281
Oh, I see.
I will try.
Reply #282
Thank you for keeping this updated! This allowed me to move back from CUI to DUI on Foobar x64. However, I am not getting field values suggestions on the genre tag, even when it is configured to do so. What could be wrong?
Reply #283
Hello,
Since I installed the new version 0.221, I no longer have a foobar crash whereas I had more than 15 in 3 days with the previous version of TagBox.
Reply #284
I've just enabled Auto Suggest with Values Currently in Database and it works for me. I assume you've set a Media Library? Trying from a panel or right click? Does it work if you type values into the configuration and use Values Below?
Up until now I've had Auto Suggest off, and whilst turning it on I had a crash, so it did cross my mind that the crashes may have been from database lookups, but it seems that @4Art6 is no longer having crashes, so the mystery continues - unless @Arash fixed more than the UI in 0.221.
Reply #285
profile/configuration/foo_tagbox.dll.cfg
"Panel TagBox" settings are not saved with only Preferences (Popup TagBox) settings.
Popup TagBox Settings: Preferences > Tools > Tagging > TagBox
Reply #286
I just released v0.221 my first attempt to fix the config page problems on different display settings, please try it and see if you still have issues.
That's clearly better.
Keep on the good job and provide us quickly scrollbars at least on panel and configuration dialog
Reply #287
Until that happens you can use the mousewheel.
Reply #288
Auto suggest works when using the fixed list, but not when I ask for values currently in database. I do have a Media Library in place.
Reply #289
Hello Everybody,
TagBox v0.220 is now available on the website, compatible with foobar2000 v2.0 (x86 and x64). Please let me know if there are any problems.
Thank you so much!!!
Reply #290
I finally could get the suggestions for the genre field to work properly, but found another strange behaviour:
I have a field (style, in this case) set to append as default behaviour. When the field already has some content, I add a semicolon and begin typing to get the options of values already in database, After choosing the value I want, the content of the box is replaced but the string I typed followed by semicolon and the value I choose from the dropdown list.
I hope this description is clear, English is not my native language. I am using version 0.221
Reply #291
I can confirm this behavior. I forgot that I updated the plugin and thought I'm crazy...
Reply #292
FYI I am also seeing this behavior @Arash
Reply #293
Please, what is the syntax for "Featuring"?
Reply #294
Seems Tagbox is causing crashes for me intermittently, but only when using the floating tagbox (not in a panel):
Also, can we get an update as to when inline editing of tags for multiple values will be fixed? (as referenced a few posts above)? Thanks
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 034C721Bh
Access violation, operation: read, address: 5547414Ah
Call path:
app_mainloop
Code bytes (034C721Bh):
034C71DBh:  CC CC CC CC CC 55 8B EC 83 EC 24 A1 64 E9 4E 03
034C71EBh:  33 C5 89 45 FC 56 8B 75 14 83 7E 54 00 74 4D 81
034C71FBh:  7D 0C 01 02 00 00 75 44 8D 45 DC 50 FF 76 04 FF
034C720Bh:  15 E4 F1 4D 03 8B 46 54 85 C0 74 30 8D 4D EC 51
034C721Bh:  FF 70 04 FF 15 E4 F1 4D 03 8B 45 10 8B 08 3B 4D
034C722Bh:  EC 7C 12 8B 40 04 3B 45 E0 7C 0A 3B 4D F4 7F 05
034C723Bh:  3B 45 F8 7E 07 8B CE E8 09 6A 00 00 8B 4D FC 33
034C724Bh:  CD 5E E8 65 34 01 00 8B E5 5D C3 CC CC CC CC CC
Stack (0116F8B4h):
0116F894h:  0116FA18 0116F9B0 77485B90 3EAE301F
0116F8A4h:  FFFFFFFE 0116F8E0 034C7210 67713757
0116F8B4h:  0116F8CC 8F0BBBC8 00000003 0116F8C8
0116F8C4h:  77B869A6 75C25454 FFFFFFFF 00000034
0116F8D4h:  0116F8F0 00000008 522C979D 0116F930
0116F8E4h:  034BB0E3 00000000 00000201 0116FA18
0116F8F4h:  87297EE8 034B9AF0 00EC2000 00070000
0116F904h:  00000000 0E362D40 00000000 00000000
0116F914h:  00000000 57F01920 933DBB08 00000001
0116F924h:  933DBB08 034EE000 034EE00C 0116F948
0116F934h:  034B9B08 8F0BBBB8 00000000 00000201
0116F944h:  0116FA18 0116F978 7747F84F 00000000
0116F954h:  00000201 0116FA18 00A21088 77BA88B0
0116F964h:  014B1700 00070000 00000201 00000000
0116F974h:  00000000 0116F9C0 7747E679 00070000
0116F984h:  00000201 0116FA18 034B9AF0 48F630B7
0116F994h:  00A21088 0116FA8C 014B1700 C0000005
0116F9A4h:  00000000 0116F990 0116F2CC 0116F9F8
0116F9B4h:  77485B90 3EAE327F 00000000 0116F9E8
0116F9C4h:  774E3856 0116FA14 0116FA04 00000000
Registers:
EAX: 55474146, EBX: 034EE004, ECX: 0116F8CC, EDX: 00000000
ESI: 87297EE8, EDI: 866CC9C0, EBP: 0116F8E0, ESP: 0116F8B4
Crash location:
Module: foo_tagbox
Offset: 1721Bh
Symbol: "foobar2000_get_interface" (+146DBh)
Environment:
App: foobar2000 v2.0
Arch: x86
UI: Default User Interface 2.0
Components:
Core (2023-04-26 12:41:48 UTC)
    foobar2000 core 2.0
foo_abx.dll (2022-08-30 13:49:34 UTC)
    ABX Comparator 2.1
foo_converter.dll (2023-04-26 12:41:26 UTC)
    Converter 2.0
foo_customdb.dll (2011-05-09 20:42:38 UTC)
    Custom Database 0.1.0_beta1
foo_discogs.dll (2020-04-15 17:24:36 UTC)
    Discogs Tagger 2.23
foo_dockable_panels.dll (2007-03-28 14:19:00 UTC)
    Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dop.dll (2010-02-20 19:51:20 UTC)
    iPod manager 0.6.6.7
foo_dsp_crossfader.dll (2010-01-14 02:46:10 UTC)
    Gapless Crossfader 1.3.4.1
foo_dsp_eq.dll (2023-04-26 12:41:20 UTC)
    Equalizer 1.2.3
foo_dsp_std.dll (2023-04-26 12:41:20 UTC)
    Standard DSP Array 2.0
foo_extm3u.dll (2007-02-01 23:10:28 UTC)
    EXTM3U playlist format plugin 1.3
foo_facets.dll (2011-08-21 06:39:34 UTC)
    Facets 1.0
foo_filedate.dll (2007-09-19 11:07:16 UTC)
    File date 1.0.4
foo_fileops.dll (2023-04-26 12:41:24 UTC)
    File Operations 2.0
foo_foobarCon.dll (2014-05-05 22:01:50 UTC)
    HTTP Control for FoobarCon 0.97.28-fc
foo_freedb2.dll (2023-04-26 12:41:20 UTC)
    Online Tagger 0.9
foo_input_dts.dll (2020-03-01 23:57:26 UTC)
    DTS decoder 0.6.8
foo_input_std.dll (2023-04-26 12:41:28 UTC)
    CD Audio Decoder 2.0
    FFmpeg Decoders 6.0
    Monkey's Audio Decoder 10.09
    Standard Input Array 2.0
foo_jesus.dll (2010-09-23 02:40:58 UTC)
    Autosave & Autobackup 10
foo_jscript_panel.dll (2019-10-19 16:07:06 UTC)
    JScript Panel 2.3.0.1
foo_jscript_panel3.dll (2024-02-03 05:09:04 UTC)
    JScript Panel 3 3.3.40
foo_lyricsgrabber.dll (2009-02-07 06:12:48 UTC)
    Lyrics Grabber 0.3.0.7 Alpha
foo_masstag.dll (2022-09-19 17:01:54 UTC)
    Masstagger 1.9
foo_mouse_gesture.dll (2010-01-19 02:20:04 UTC)
    Mouse Gesture Host 0.5.2
foo_musicbrainz.dll (2023-02-24 03:53:04 UTC)
    MusicBrainz Tagger 0.5.0
foo_navigator.dll (2010-02-20 01:13:14 UTC)
    Navigator 0.64
foo_playlist_attributes.dll (2023-05-22 01:21:58 UTC)
    Playlist Attributes 1.0.3
foo_popupplus.dll (2008-04-24 20:24:18 UTC)
    PopUp Plus 20080424
foo_random_pools.dll (2023-05-22 02:35:04 UTC)
    Random Pools 2.0.3
foo_run.dll (2023-01-17 13:50:06 UTC)
    Run services 0.4.5
foo_runcmd.dll (2010-01-07 23:32:34 UTC)
    Run Command 1.1
foo_scheduler.dll (2020-03-01 23:57:26 UTC)
    Scheduler 4.19
foo_scrobble.dll (2022-09-06 05:43:00 UTC)
    Scrobble 1.6.0.22456
foo_sid.dll (2022-02-13 21:04:22 UTC)
    sidplay2 1.91
foo_simplaylist.dll (2011-08-21 06:39:34 UTC)
    SimPlaylist 1.0
foo_softplaylists.dll (2012-10-10 20:44:48 UTC)
    Soft Playlists 2012-10-10
foo_spider_monkey_panel.dll (2020-04-15 17:36:02 UTC)
    Spider Monkey Panel 1.2.3
foo_stopafteralbum.dll (2011-01-22 01:47:44 UTC)
    Stop after album 1.5
foo_tagbox.dll (2023-09-12 05:15:18 UTC)
    TagBox 0.221
foo_textdisplay.dll (2011-06-28 02:30:28 UTC)
    Text Display UI Element 1.1 beta 1
foo_texttools.dll (2022-09-16 16:00:30 UTC)
    Text Tools 1.1
foo_ui_columns.dll (2023-09-27 03:19:08 UTC)
    Columns UI 2.1.0
foo_ui_std.dll (2023-04-26 12:41:30 UTC)
    Album List 2.0
    Decoding Speed Test 2.0
    File Integrity Verifier 2.0
foo_uie_biography.dll (2010-12-11 13:47:22 UTC)
    Biography View 0.4.2.4
foo_uie_esplaylist.dll (2011-05-30 15:41:00 UTC)
    EsPlaylist 0.1.3.9
foo_uie_tagger_mod.dll (2009-09-20 21:49:44 UTC)
    Tagger Mod Panel Window 1.1.0.6 [Sep 20 2009 - 23:33:24]
foo_uie_wsh_panel_mod.dll (2020-04-16 10:42:46 UTC)
    WSH Panel Mod 1.5.6
foo_unpack.dll (2023-04-26 12:41:28 UTC)
    ZIP/GZIP/RAR/7-Zip Reader 2.0
foo_upnp.dll (2015-01-13 20:25:18 UTC)
    UPnP/DLNA Renderer, Server, Control Point 0.99.49
foo_vis_milk2.dll (2024-02-20 02:51:42 UTC)
    MilkDrop 2 Visualisation 0.0.230-alpha
foo_vis_shpeck.dll (2009-09-28 15:32:16 UTC)
    Shpeck - Winamp vis plugins wrapper 0.3.7
foo_w7shell.dll (2010-01-17 08:09:20 UTC)
    Windows 7 integration 0.2.9.1
foo_youtube.dll (2023-10-28 01:53:06 UTC)
    Youtube Source 3.9
Recent events:
Opening track for playback: "C:\Users\Magnu\Music\S\Squarepusher\Dostrotime\10 - Squarepusher - Domelash.flac"
foo_scrobble: Submitting track
Biography Server: allmusic album review / biography: Dostrotime / Squarepusher: not found Status error: 0
Biography Server: allmusic biography: Squarepusher: not found
Autosaving... (I)
Configuration saved in: 0:00.168296
Autobackup: Backed up 99 items to autobackup.20240331-225613.zip
Autosaving... (I)
Configuration saved in: 0:00.169280
Autobackup: Backed up 99 items to autobackup.20240331-231553.zip
Autosaving... (I)
Configuration saved in: 0:00.169681
Autobackup: Backed up 99 items to autobackup.20240331-232213.zip
Opening track for playback: "C:\Users\Magnu\Music\S\Squarepusher\Dostrotime\11 - Squarepusher - Heliobat.flac"
Autosaving... (I)
Configuration saved in: 0:00.196642
Autobackup: Backed up 99 items to autobackup.20240401-093653.zip
Opening track for playback: "C:\Users\Magnu\Music\S\Squarepusher\Dostrotime\12 - Squarepusher - Arkteon 3.flac"
Autosaving... (I)
Configuration saved in: 0:00.174423
Autobackup: Backed up 99 items to autobackup.20240401-095943.zip
Opening track for playback: "C:\Users\Magnu\Music\C\Coaltar of the Deepers\RABBIT EP\01 - Coaltar of the Deepers - HALLUCINATION ’18.mp3"
Autosaving... (I)
Configuration saved in: 0:00.182220
Autobackup: Backed up 99 items to autobackup.20240401-102123.zip
Machine specifications:
OS: Windows 10.0.22631 x64
CPU: AMD Ryzen 7 5700G with Radeon Graphics, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2 AVX LZCNT
CPU threads: 16
Audio: Speakers (High Definition Audio Device); 1 - LG FULL HD (AMD High Definition Audio Device)
