Topic: HOw to show Bits Per Sample (Read 10365 times) previous topic - next topic
Hi
I'm looking for a bit of help.
I would like to have a column that shows Bits Per Sample, is this possible. I can't seem to find the code to inable this.
I am using ColumnII playlist.
GAry
it works fine in a column here.
screenshot
Personally, I use this for a column:
$if($strcmp(%__encoding%,lossy),%bitrate% kbps,%__bitspersample% bit)
Then I can get rid of the bitrate column, since bitrate is not really important for lossless files, and bitdepth doesn't exist for lossy files.
elevatorladylevitateme
Hi
That fixed it, I was using [%bitspersample%], which didn't work.
Many thanks for your help.
G.
this is wonderful. thank you
whenever I have to do subtraction I'm like "wut?"
thank you for the advise! I was having the same issue.
