Topic: GXLame - Low-bitrate MP3 encoder. (Read 44513 times) previous topic - next topic
From yesterday:
GXLame-t3.
Changelog:
- Slight tuning (some artifacts addressed)
- Improved high frequency handling (helps stabilize cases of fading backbeat, etc)
- Slight speedup
Grab it to go™.
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
  • lvqcl
  • Developer
I noticed that gxlame doesn't like quiet samples like bruhns, bibilolo, Chariots of Fire (=sample02 from last mp3 test) etc.
  • lvqcl
  • Developer
Bitrate vs quality settings for LAME 3.98.4, LAME 3.99 alpha 6 (default and vbr-new) and GXLame:
...and alpha7 vbr-new.
quality scale for GXLame was reverted to coincide with LAME (gxlame -V0 <=> lame -V9.999, gxlame -V20 <=> lame -V8, etc.)
Test set: modern pop and rock music.
  • Last Edit: 03 May, 2010, 12:00:10 PM by lvqcl
Thanks for the bitrate curve and the report!
Could you direct me to these sample clips? A quick search turns up a bunch of threads referring to them but deleting all attachments thereafter. Surely there's a central location for these killer samples?
Thanks again!
PS: What version of GXLame did you use for the bitrate curve test?
  • lvqcl
  • Developer
http://www.hydrogenaudio.org/forums/index....st&p=509158
http://www.mp3-tech.org/tests/aac_48/samples/  - sample3
http://www.hydrogenaudio.org/forums/index....st&p=689051
I doubt it...
t3 (Apr 29 2010).
  • db1989
  • Global Moderator
Reply #30
Does this version have a different default VBR mode? The changelog only covers a2, and most of the listed updates are bug fixes and input format support.
  • Last Edit: 01 May, 2010, 04:20:06 PM by dv1989
  • lvqcl
  • Developer
No, the default mode in 3.99a6 is the same as the default mode in 3.98.
--vbr-new in 3.99a6 is yet another (new!) VBR mode.
  • db1989
  • Global Moderator
 Thanks for the answer! I wonder how it'll compare in listening tests.
  • lvqcl
  • Developer
Reply #33
Well... I compared 3.99a6 -V6.5 and -V7 --vbr-new. Default VBR mode is better IMHO.
  • Aleron Ives
Reply #34
Forgive my ignorance, but if the VBR new in 3.98 has been under development for such a long time and finally as of 3.98 has become the default mode, why is 3.99 introducing yet another VBR mode?
Reply #35
Sorry, but were I can download LAME 3.99 alpha 6 exe?
  • db1989
  • Global Moderator
Reply #36
Google's first result for "LAME 3.99a6"  is lame.bakerweb.biz, which automatically compiles and uploads on Mondays, Wednesdays and Fridays. I believe that this is quite a 'famous' site for LAME compiles, albeit one that is not mentioned in Hydrogenaudio's pinned topic or Knowledgebase.
Reply #37
Oh, thank you)
  • lvqcl
  • Developer
Reply #38
current version is alpha 7  vbr-new behavior was tuned again...
Reply #39
GXLame is based on the stable version, not the alpha, so none of these changes made it in. But that's okay, since GXLame uses another strategy. Here you go!
GXLame-t4:
- Reworked ath system
- Lowpass raised (again) also at high bitrates (20.5Khz at V100)
- Tuning
- Changes in bitrate mapping as follows:
V0:   64kbps (resampling to 32Khz takes place at V5)
V10:  79kbps
V20:  85kbps
V30:  96kbps
V40:  112kbps
V50:  128kbps
V60:  146kbps
V70:  162kbps
V80:  185kbps
V90:  224kbps
V100: 256kbps
I addressed some problem samples (some more than others, for various reasons), but in general I think you'll find perceptual quality has increased tremendously with this release. Special attention was given to "cleaning" up the sound and reducing ringing in certain situations. V20 (85kbps) is now perfectly usable on my player while on the go. (Of course, a deafeningly noisy bus commute with my rather strange collection of music blaring through cheap headphones doesn't vouch for everyone).
This marks my first "alpha" release. Note that there is much left to be done. The new ath system has yet to mature and isn't yet used to its full potential. Also, abr (still) isn't tuned yet. Speed and stability have yet to be evaluated in the long haul. I recommend you use -f if things are moving too slowly for you, but speed tweaking isn't a priority now--the focus is on quality at very low bitrates (V10-V30 in particular).
Let me know of any regressions, no matter how obvious or obscure.
Cheers!
Link
  • Last Edit: 09 May, 2010, 05:58:47 AM by The Sheep of DEATH
  • lvqcl
  • Developer
Reply #40
Killer samples for GXLame-t4 -V 30:
mama_original (Also waste_original from this thread is a problem sample too)
es50
newkid
badvilbel
Reply #41
Hi. So I see vorbis got another new release recently. Anyway,
GXLame-t4.5
  • IgorC
Reply #42
Thank You,
Nice to see new version.  It looks good at first sight. It really has less warbling but maybe  at cost of some noise.
Will get a try to it in these days.
It is particularly interesting for me bitrate  96 kbps (V30) .
Don't know if it is worth to compare to some of the  LAME versions (settings) or other MP3 encoders which are tuned for low bitrates.
Reply #43
Thank You,
Great news! A comparison would certainly be useful. I've compared to LAME a lot, but no other MP3 codecs at these rates.
Anyway, let me sneak through an early-stage t5.
GXLame-t5:
- Synced (selectively) with LAME 3.99b0
- Small ath minval bugfix (introduced in t4)
- Better normalization of quality between quiet and "noisy" audio (needs testing!)
- Fast mode (-f) is much faster (now on par with aotuv venc builds) with better quality approaching that of default mode
- Changes in low bitrate mapping to be more geometrically consistent and to take advantage of new quality normalization at even lower bitrates:
V100: 256kbps
V90:  224kbps
V80:  185kbps
V70:  162kbps
V60:  146kbps
V50:  128kbps
V40:  112kbps
V30:  96kbps
V20:  85kbps
V10:  75kbps
V0:    64kbps (actually 56kbps @ 32KHz
; auto resampling to 32Khz takes place at V5 and below)
GXLame-t4.5 is still the recommended version for actual use, while t5 is a new branch. Although t5 it is less mature than t4.5, it may produce better overall quality in some (few? most? 'all?') cases, but more testing is needed. It would be very helpful if you could compare it to t4.5 (or the popular t3, for that matter) on normal music. A comparison of average bitrates (at V20, for instance) between these versions would also be welcome, as would a comparison of normal and fast mode. As usual, grab it in the release post.
Again, let me be clear...
GXLame-t4.5 is the recommended version. It is 'r1' for GXLame. GXLame-t5 hasn't been tuned to the extent that t4.5 has been. (However, if you can, please do test it and compare the quality of t5 vs t4.5 on a variety of music).
Reply #44
Just for the record (in case I'm not around for a test announcement like before), GXLame-t5.2 (or 5.3) can be used in any upcoming listening tests. In fact, I strongly encourage it and hereby enter it in any and all such tests.
  • holmus
Reply #45
I second that motion.
  • Last Edit: 20 August, 2011, 12:03:52 PM by db1989
  • C.R.Helmrich
  • Developer
Reply #46
I'm also interested in the performance of the latest MP3 encoders. Given that the public AAC test at ~100kbps will finish today (if you want to participate, now is the last chance!), it would be nice to set up the same test with only MP3 codecs during the next few months.
Any volunteers? I probably can't since I work for one of the codec providers...
Chris
  • moozooh
Reply #47
A bit off-topic, but working for a codec developer shouldn't make a difference since the tests conducted are double-blind. Unless you can specifically pick up the codec you favor (which, mind you, isn't too hard in many cases, as most codecs have unique and identifiable artifact signatures at low bitrates), and give it higher marks on purpose, you're on equal ground with any other volunteer.
Infrasonic Quartet + Sennheiser HD650 + Microlab Solo 2 mk3.
  • IgorC
Reply #48
After conducting the last public test I've understood why all previous organizators of public tests weren't the developers of competitor codecs. It's for a really good reason.  Even if the person is well known.
I won't go into details for an obvious reason.
  • moozooh
Reply #49
Ah, I erroneously assumed C.R.Helmrich was asking for volunteers to participate in an existing upcoming test, not organize a new one. In that case it makes sense.
