Topic: .m2ts plugin (Read 6132 times) previous topic - next topic
  • Fertypa
.m2ts plugin
Hi.
Is there any way to open .m2ts files in fb2k? Any plugin or even, convert .m2ts to FLAC or another lossless?
The .m2ts is audio only, 24/96 5.1 DTS-HD Master Audio
  • Last Edit: 19 April, 2010, 01:16:43 PM by Fertypa
  • db1989
  • Global Moderator
.m2ts plugin
Buy a legal copy of the album, then you'll get it in a proper format, and so won't have this problem.
To answer your question, according to Google there doesn't appear to be a plugin. But other searches will provide information on .m2ts files and perhaps how you can convert them into a usable format. Why the 'releaser' (pirate) decided to convert an SACD to Blu-ray format is beyond me.
  • Last Edit: 19 April, 2010, 01:05:36 PM by dv1989
  • ExUser
  • Read-only
.m2ts plugin
http://en.wikipedia.org/wiki/.m2ts
What does .mt2s have to do with SACD, dv1989?
  • db1989
  • Global Moderator
.m2ts plugin
Before being edited, the original post quoted a release log including lines something like:
Source: SACD
Format: Bluray Lossless Audio
So I assumed it had been converted from the former.
OP: Way to edit your post to hide the fact that it's about pirated files, while not acknowledging my post--which, to reiterate, states that searching suggests that there is no plugin, but will probably provide information on converting the files to a more supported (and logical) format.
  • Last Edit: 19 April, 2010, 02:03:02 PM by dv1989
.m2ts plugin
use eac3to to convert it to FLAC.
  • ZhuGeLiang
.m2ts plugin
Foobar can currently only play dts (not dts-hd).
To play the dts:
  Use tsmuxer to demux the dts core from the dts-hd.
To play the dts-hd:
  Use tsmuxer to demux the dts-hd and convert it to flac with eac3to and arcsoft.
