Topic: Comparing FLAC and Monkey's (Read 14149 times) previous topic - next topic
  • witt
Reply #50
Is there any frontend for MetaFlac?  I'm using WinXP, and the command-line box is hell to use when you're trying to apply replaygain to multiple files.
Foobar2000 can apply ReplayGain to mutiple files very easily.
foobar2000 Wiki for Japanese Users
http://foobar.s53.xrea.com/fbwiki/
  • Moguta
Reply #51
Thank you!  Foobar did it perfectly.
MultiFrontend seems to mess up ReplayGain.  Although it is still great for converting one format to another.
  • Frank Klemm
Reply #52
APE gets you slightly smaller files, while FLAC is more of a standard and isn't as annoying to get to work under Linux.
I use APE.
Nonsense.
Here FLAC do not compile and MAC do compile.
Is there a list which tools and versions must be installed to compile FLAC?
--  Frank Klemm
  • Frank Klemm
Reply #53
I use only WavPack for lossless and many times for lossy compression. It's very fast and when I compared it with FLAC, WavPack always ended with a bit better compression.
Default Wavpack is ~2x faster than default FLAC on encoding and gets about 1% better compression, but FLAC still decodes faster (~15%), which does matter on hardware players.  In any case, Wavpack's compression/speed and decompression/speed ratio is very good.  I have toyed with the idea of adding its method to FLAC now that their two licenses are compatible; I'm only worried about be more vulnerable to patent claims (not Bryant's, someone unknown third person's) since the method is more complicated.
Josh
BTW:
Me (and also at least 5 other persons) are searching for a FLAC which can be compiled on a
2 year old system  OR  for FLAC binaries which are linked against glibc 2.1 (and not glibc 2.2).
Update of these machines may be possible, but will end up in a replacement of nearly the whole
system.
And there is also at least a person searching for a libc5 version of FLAC. The machine
used is a AMD K-5/166 with 32 MB RAM. Modern Linux distributions do not start on these
machine.
Is there any chance to get these versions?
--  Frank Klemm
  • Frank Klemm
Reply #54
Cool, I thought MAC was closed-source.  So both FLAC and MAC are open.
And thanx for directing me to the plugin... I definitely overlooked it since the sourceforge page isn't unfamiliar to me.
One thing I would like to know that didn't get answered...
1) Does FLAC support surround-sound ( >2 channels)?
FLAC do support more than 2 channels.
APE, LPAC, OptimFROG, LA do not support more than 2 channels.
--  Frank Klemm
  • jcoalson
Reply #55
Josh
BTW:
system.
machine.
[argh, something goes seriously wrong between this forum and konqueror 3]
Frank, just what about the autoconf system does not work on these systems?
Josh
  • Last Edit: 14 April, 2003, 08:57:57 PM by jcoalson
