Topic: Can't use the ogg encoder with foobar (Read 3132 times) previous topic - next topic
  • keicar
Using foobar 1.0.1, whenever I try to convert anything to ogg with it, immediately after starting the conversion, I get two "oggenc2.exe has stopped working" errors, both with the same message:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   oggenc2.exe
  Application Version:   0.0.0.0
  Application Timestamp:   4bb203c3
  Fault Module Name:   oggenc2.exe
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   4bb203c3
  Exception Code:   c0000005
  Exception Offset:   0000ffd0
  OS Version:   6.1.7600.2.0.0.256.1
  Locale ID:   2057
  Additional Information 1:   0a9e
  Additional Information 2:   0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:   0a9e
  Additional Information 4:   0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104...mp;clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Then errors like this for every file:
Source: "C:\Users\Chris\Music\Hardcore\Euphoria - 2 Damn Beautiful.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "C:\Users\Chris\Desktop\oggconversions\Euphoria - 2 Damn Beautiful.ogg"
Additional information:
Encoder stream format: 44100Hz / 2ch / 32bps
Command line: "C:\Program Files (x86)\Foobar2000\oggenc2.exe" -s 1610194076 -Q -q10.000000 - -o "Euphoria - 2 Damn Beautiful.ogg"
Working folder: C:\Users\Chris\Desktop\oggconversions\
  Conversion failed: The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters
Source: "C:\Users\Chris\Music\Hardcore\Euphoria - No Way Out.mp3"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "C:\Users\Chris\Desktop\oggconversions\Euphoria - No Way Out.ogg"
Command line: "C:\Program Files (x86)\Foobar2000\oggenc2.exe" -s 1148555852 -Q -q10.000000 - -o "Euphoria - No Way Out.ogg"
What I don't understand is that I've used several different oggenc versions all all fail with these kinds of errors. BUT, when I run them on their own (from the command line) they work fine??  Did this get broken 1.0.1? I should also note that the same happens in the 1.0.2 beta and 1.0.0.
  • Dandruff
