Topic: any way to tell which compression method was used? (Read 6461 times) previous topic - next topic
Is there any way to figure out what compression mode was used? (ie. fast, high, extra high)
i want to make sure anything i download is extra high, and if its not, transcode it to extra high as not to waste space...
alt-3 (view file info) in winamp w/ APE plugin works for this.  Would be nice if fb2k showed it somewhere...
ahh... thanks...
*heads to the fb2k forum to ask about adding foobar2k support for this*
Strange... I was tending to think (reading numerous topics on this board) that F2K is THE ULTIMATE PLAYER, while WinAmp definitely sucks...
How come that WinAmp shows that info, and F2K not?
I CAN'T BELIEVE IT!
dBpowerAMP Music Converter, hold the mouse over the APE file.
I CAN'T BELIEVE IT!
Because it is, as you said, "The Ultimate Player".
foobar2000 shows that info in the properties-box...
Perhaps 3 years ago it didn't, nice resurrecting a 3 year old thread.
Whoops my bad... how do I end up with a 3-yr old thread??
Note to self: Do a triple-check before posting when you're in the midst of installing troubleshooting Windows 2003 Server...
Windows 2003 server indeed.
err... i'm not using windows any more ;)
