Topic: Burning CD's (Read 1710 times) previous topic - next topic
Burning CD's
Whenever I right click on the files I want to burn select convert then write audio cd it takes me straight here http://support.microsoft.com/kb/952011. Now I did go and update some components, but only the ipod manager and columns ui. Any ideas why I can no longer write cd's?
  • shakey_snake
  • Moderator
Burning CD's
foo_burninate no longer uses old versions of Nero as the burning engine, but uses IMAPIv2
You need to install the appropriate IMAPIv2 runtime from Microsoft from that page.
If you were on Vista SP1 or later this would already be on your system.
elevatorladylevitateme
Burning CD's
Thanks for your help! I got it working just fine now. Good thing too cause this is the best audio player I've ever used and I didn't want any reasons not to use it! =]
