Topic: HDCD Decoder (Read 204540 times) previous topic - next topic
  • Cheung
HDCD Decoder
Reply #50
Okay, I made a little progress.  Found a Reset Page tab at the bottom of the Output window.  When I clicked on that it displayed my output as being 16-bit but it remained grayed over. And it still says Output data format will be chosen automatically for the selected device.
I would think that my  X-Fi Titanium Fatal1ty Pro sound card would have the capability to produce 24-bit output, no?
My whole purpose of trying to set Foobar output to 24-bit is so I can make use of the HDCD DSP plugin I installed.
  • Last Edit: 26 June, 2010, 01:16:25 PM by Cheung
HDCD Decoder
Reply #51
Your OS supports 32bit Direct Sound processing so that page is disabled. Foobar passes the data still in 32bit and lets the OS make the decisions on output format.
  • Cheung
HDCD Decoder
Reply #52
    Thank you for your prompt and clarifying reply Purple Monkey
I installed and activated the HDCD decoder plugin then downloaded some HD-CD lossless music from the Reference Recordings site.  The files were delivered in FLAC.  While the music was playing in Foobar  I went to see what was happening at View / Console and it was reporting HDCD detected.  Nice!
  • Last Edit: 26 June, 2010, 04:24:34 PM by Cheung
  • kode54
HDCD Decoder
Reply #53
I've updated the component to version 1.4, which now uses a new interface that requires foobar2000 1.1 or newer, beta included. It will automatically decode HDCD tracks from supported inputs, currently CDDA, WAV, FLAC, and WavPack. It will report whether the tracks contain HDCD data through an info tag, "hdcd". So you can add a $if(%__hdcd%) or $if($info(hdcd)) to your title formatting scripts to display the HDCD status of the current track.
I will add other HDCD information tags if anyone wants them. Probably just whether the current track is using peak extension and/or what the current gain level is.
HDCD Decoder
Reply #54
And does this decoder (or postprocessor?) work for foo 1.1 converter?
$if(%__hdcd%) gives ""[INVALID SIF SYNTAX]", %__hdcd% gives "?", $info(hdcd) gives no text, while HDCD 1.3 shows "HDCD detected" in foobar2000 console for this track
  • Last Edit: 25 July, 2010, 05:37:53 PM by Steve Forte Rio
  • Yirkha
  • Moderator
HDCD Decoder
Reply #55
"$if(%__hdcd%,HDCD ,)" or "HDCD: [%__hdcd%]" or "HDCD: $if2($info(hdcd),no" etc.
  • Hancoque
HDCD Decoder
Reply #56
That would be much appreciated.
  • mjb2006
HDCD Decoder
Reply #57
I did have foobar2000 1.0.3 installed, along with version 1.3 of foo_dsp_hdcd. I then installed fb2k 1.1 beta 1. The Components page in the Preferences shows HDCD decoder 1.3 is still installed, but when I press the 'Get updates' button, it's not telling me there's a new version of your component available. Is this expected behavior?
HDCD Decoder
Reply #58
I'm adding the column to DUI playlist and what I see for my HDCD track is:
$if(%__hdcd%,HDCD ,) - no text
HDCD: [%__hdcd%] - "HDCD: "
$if2($info(hdcd),no) - "no"
But I'm sure that track has HDCD layer - it has been detected by HDCD DSP 1.3
I think it happens because the plugins have different names (foo_dsp_hdcd and foo_hdcd)
  • Last Edit: 26 July, 2010, 04:13:10 AM by Steve Forte Rio
HDCD Decoder
Reply #59
This does not appear to work for the DUI columns, I have the same problem as you  Only the status/window title works with this info.
Can someone confirm that the HDCD processing is carried out before replaygain processing?
  • Last Edit: 26 July, 2010, 05:10:30 AM by Walrusbonzo
HDCD Decoder
Reply #60
Thank you very much! Works fine with $if(%__hdcd%, | HDCD,) in the status bar
HDCD Decoder
Reply #61
Question about foo_hdcd 1.4 using with foobar 1.0.3.
Does not "HDCD Scan" (at Context Menu > Util) work?
hdcd.exe reports as HDCD, but "HDCD Scan" of foo_hdcd reports blank fields...
  • Last Edit: 27 July, 2010, 12:11:24 PM by madoka@ex-sounds
<name>madoka</name>
<uri>http://codecs.ex-sounds.net/</uri>
  • kode54
HDCD Decoder
Reply #62
foo_hdcd requires foobar2000 1.1 or newer for the decoder to actually work, and the scanner requires that decoder to be used by inputs for it to detect anything.
HDCD Decoder
Reply #63
Thank you very much
I'm waiting for release of stable version 1.1
<name>madoka</name>
  • Alex B
HDCD Decoder
Reply #64
Replay Gain works now, but I think the current implementation is still a bit problematic. If the files have been measured using a standard decoder the old values are now incorrect when the files are played through the HDCD Decoder and it reduces the volume level. It is possible to reanalyze the files, but then the values will be incorrect on other players.
At least it would be nice to have an easily accessible on/off switch for HDCD decoding so that it could be switched off when mixed playlists are played and when Replay Gain is analyzed.
Here is a screenshot of the old and newly analyzed "HDCD" RG values for one album:
EDIT
In general, HDCD decoding is rather useless when peak extension is not available. The album in the screenshot doesn't have it. Actually, only a very few of my HDCD albums seem to have it.
  • Last Edit: 28 July, 2010, 03:50:49 PM by Alex B
some archived old tests: http://listening-tests.freetzi.com
  • kode54
HDCD Decoder
Reply #65
I've added real-time HDCD info reporting, using the info variables "hdcd_gain," "hdcd_peak_extend" and "hdcd_transient filter." The latter isn't supported by this decoder, and I don't think it would be terribly useful for any decoder that doesn't upsample the output to 88200Hz or higher anyway.
Example addition to status bar formatting:
$if(%__hdcd%,' ('HDCD - pe:%__hdcd_peak_extend% tf:%__hdcd_transient_filter% gain:%__hdcd_gain%')',)
  • Last Edit: 30 July, 2010, 09:22:23 PM by kode54
  • Nowings69
HDCD Decoder
Reply #66
HDCD decoder 1.5 with my Foobar2K
HDCD mode
Normal mode
Thank you so much
  • Last Edit: 31 July, 2010, 03:50:40 AM by Nowings69
HDCD Decoder
Reply #67
Thx.
And when it will be possible to decode HDCD from TAK source?
  • kode54
HDCD Decoder
Reply #68
Once the interface is finalized, and the TAK decoder component is updated to use it.
  • lvqcl
  • Developer
HDCD Decoder
Reply #69
I think that converter interface should have an option to en/disable such components.
  • n A r
HDCD Decoder
Reply #70
Thank you so much
Hey, your config is fabulous  Would you mind sharing it ?
Best regards,
nAr
  • Nowings69
HDCD Decoder
Reply #71
Thank you so much
Best regards,
nAr
Sure
But right now
http://www.lastfm.jp/user/asajan/journal/2...r_my_foobar2000
Well,my FB2K is for HDCD,AccurateRip and LastFm right now
ttp://www.megaupload.com/?d=I38QJKFD
I know but this code
// PerSecond
$if(%__hdcd%,$imageabs(1,0,\images\HDCD.png,alpha-180),)
$if3($if(%__hdcd%,$align(right,middle)Peak extend = %__hdcd_peak_extend%$char(10) Transient filter = %__hdcd_transient_filter%$char(10) Gain = %__hdcd_gain%,),$if(%__hdcd%,$align(right,middle)Peak extend = %__hdcd_peak_extend% $char(10)  Transient filter = %__hdcd_transient_filter%$char(10) Gain = %__hdcd_gain%,),
$ifequal($len($ext(%filename_ext%)),9,$imageabs2(220,60,0,0,220,60,20,8,C:\program files\foobar2000\images\lastfm2.jpg,),
$if(%ACCURATERIPID%,$imageabs2(200,50,0,0,200,50,30,3,C:\program files\foobar2000\images\accuraterip.jpg,alpha-240)
$align(center,bottom)$if(%ACCURATERIPID%,%ACCURATERIPID%))),
$ifequal($len($info(encoding)),5,$imageabs(110,14,images\foobar2000.png,),),
$if(%isplaying%,$imageabs2(200,50,0,0,200,50,30,3,C:\program files\foobar2000\images\accuraterip.jpg,)
$align(center,bottom)disk not present in database,),)
  • Last Edit: 02 August, 2010, 08:37:03 AM by Nowings69
  • n A r
HDCD Decoder
Reply #72
Thanks very much !
Will try it ASAP
Brds,
n A r
  • Last Edit: 02 August, 2010, 01:47:13 PM by shakey_snake
  • n A r
HDCD Decoder
Reply #73
I'm sorry, I tried but foobar doesn't start, error.
I'm on Windows 7 32 bit BTW. I think profile folder is not correct, I can't load any new one.
I ended up re-installing foobar2000, and I don't get the style.
Sorry, all this is off topic the hdcd decoder
To get more on the subject, here is my formating template for implementing hdcd syntax ( foobar 1.1 beta 1 & hdcd decoder 1.5 )
%codec% | %bitrate% kbps | %samplerate% Hz | %channels% | %playback_time%[ / %length%] $if(%__hdcd%,' 'HDCD - Peak Extend: %__hdcd_peak_extend% Transient Filter: %__hdcd_transient_filter% Gain: %__hdcd_gain%' ',)
brds,
n A r
  • Last Edit: 03 August, 2010, 04:55:27 AM by n A r
HDCD Decoder
Reply #74
How do I simply identify if a song has HDCD encoded as DTS does? in the status bar? Where do you put this code?
  • Last Edit: 03 August, 2010, 10:05:38 PM by Yirkha
