Topic: Implementing asyncronous IDropTarget (Read 3542 times) previous topic - next topic
Hello all,
I am implementing an asyncronous IDropTarget in my DUI. I woud like to adhere SDK docs and do the Drop IDataObject processing asyncronously. It seems the correct way of doing this is to use playlist_incoming_item_filter_v2::process_dropped_files_async method. However, it seems a bit hard to use since I found that the IDataObject contains no IID_IAsyncOperation interface (when dragging items from a playlist). I found this fact by calling pDataObj->QueryInterface(IID_IAsyncOperation, (void **) &asyncOperation); which returns E_NOINTERFACE.
How to do async prosessing of Drop if the interface is not supported?
Thanks,
-kerpondile
virtual void process_dropped_files_async(interface IDataObject * p_dataobject,t_uint32 p_op_flags,HWND p_parentwnd,process_locations_notify_ptr p_notify) = 0;
playlist_incoming_item_filter_v2::process_dropped_files_async() manage for you the async creation of metadb handles contained in the IDataObject structure, and on completion will call
p_notify->on_completion() (in the main thread).
example:
class  dropped_items_process_locations_notify : public process_locations_notify {
public:
    dropped_items_process_locations_notify(controller_window::context_menu_action_t action) : m_action(action) { }
    void on_completion(const pfc::list_base_const_t<metadb_handle_ptr> & p_items) {
             // do something here
    void on_aborted() {    }
private:
    controller_window::context_menu_action_t m_action;
HRESULT __stdcall controller_window::Drop(IDataObject * pDataObject, DWORD grfKeyState, POINTL pt, DWORD * pdwEffect) {
        service_ptr_t<process_locations_notify> completion = new service_impl_t<dropped_items_process_locations_notify>(action);
        t_uint32 flags = playlist_incoming_item_filter_v2::op_flag_background|playlist_incoming_item_filter_v2::op_flag_delay_ui;
        static_api_ptr_t<playlist_incoming_item_filter_v2>()->process_dropped_files_async(pDataObject, flags, *this, completion);
    return S_OK;
example: ...
I understand this, and I've done something similar to you example. The problem is that I cannot change pdwEffect in the dropped_items_process_locations_notify and that's why I asked why isn't async processing of IDataObject supported?
For example, if the on_aborted is called,  I'd like to return DROPEFFECT_NONE
Then, you probably want to call playlist_incoming_item_filter::process_dropped_files_check_ex() in your DragEnter() implementation of  the IDropTarget interface to accept or reject dropped items, then use playlist_incoming_item_filter_v2::process_dropped_files_async() normally in Drop()...
process_dropped_files_check_ex() is fast, opposite to process_dropped_files_async() that can take some time to execute and which should IMHO only called in Drop().
This what I have done and I guess I have no other choice, probably sufficient for my needs...Thanks!
