Topic: convert to .ape with foobar (Read 6306 times) previous topic - next topic
  • Gapkiller
hi everyone,
I always get Object not found errors when converting to ape...
An error occurred while finalizing the encoding process
(Object not found) : "C:\...\...\Desktop\Akron-Family - Live at KCRW Morning Becomes Eclectic\Akron-Family - (04) Woody Guthrie's America.ape"
Conversion failed: Object not found
parameters:
what's wrong?
How many characters has the path to the file (incl. filename)? Your exemplar is allready 120 characters long.
Avoid paths longer than 255 Characters (incl. drive letter and filename).
.halverhahn
  • Gapkiller
I thought that too but the whole path is definitely
less than 255 characters.
I'm clueless, any idea's?
  • Synthetic Soul
  • Global Moderator
Your settings certainly look fine.
Have you tried with a short, simple file path?  Also, is it possible (not sure how) that your naming scheme is causing problems?  Do you have enough disk space?
I'm on a horse.
  • Gapkiller
Free space: 52 GB
Latest MAC.exe is located in foobar2000 folder.
I don't think that %title% could cause any errors...
1 out of 1 tracks converted with major problems.
Source: "Z:\Music Library\Atomâ„¢ - iMix miniLP\Atomâ„¢ - (02) Hallo, Wie Geht Es Dir (Oye Como Va).flac"
An error occurred while finalizing the encoding process (Object not found) :
"C:\Dokumente und Einstellungen\.....\Desktop\Hallo, Wie Geht Es Dir (Oye Como Va).ape"
Source: "Z:\Music Library\CoH - Above Air\CoH - (04) Dancing In Silence.flac"
An error occurred while finalizing the encoding process (Object not found) : "C:\Dancing In Silence.ape"
  • ustas
Same problem with very short path! If I do track by track convertions all working good, if I do big image file, that ERROR happing.
Foobar 1.1.11, latest Monkey Audio. Same shit happening time to time with WV converter.
PEACE, Me.
  • lvqcl
I'm not sure that Monkey's Audio support wav files > 2GB.
